finger print scanner
James333
Post by James333 »
Hi i would love to order the finger print scanner and start on a project of mine for an invention. Im very new to this and don't know all of the things i need including the scanner its self. I've watched the tutorial video on putting the scanner together, but i, not sure on what else i need to order with the scanner and breadboard etc. Please Help and explain and give me the part numbers! Thank you! :D
adafruit_support_rick
Re: finger print scanner
All you really need is the fingerprint sensor and an arduino to control it. The breadboard is optional, but can make things easier. You'll need jumper wires if you're planning to use a breadboard.
Our Tutorial shows how to wire things up and use the sensor. The tutorial's sidebar has links to the store for the sensor, Arduino Uno, and jumper wires.
http://learn.adafruit.com/adafruit-opti ... r/overview
We have several sizes of breadboard in the store:
http://www.adafruit.com/index.php?main_ ... breadboard
nurlin27
Post by nurlin27 »
hi. i have some problem with my fingerprint. i already download the adafruit-fingerprint folder. then i copy the folder at my arduino library.
after that, i want to run the enroll program. but the output is not appear and the data also not save.
i hope u can help me plss. i dnt know what i want to do anymore .
this is the output
Adafruit Fingerprint sensor enrollment
Found fingerprint sensor!
Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as...
Enrolling ID #9
Waiting for valid finger to enroll as #9.
Image taken
Image converted
Remove finger
ID 9
Place same finger again
............................Image taken
Image converted
Creating model for #9
Unknown error *here the problem
this the the part of the error
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
products from Adafruit!
#include <Adafruit_Fingerprint.h>
#include <SoftwareSerial.h>
uint8_t id;
uint8_t getFingerprintEnroll();
// Software serial for when you dont have a hardware serial port
// pin #2 is IN from sensor (GREEN wire)
// pin #3 is OUT from arduino (WHITE wire)
// On Leonardo/Micro/Yun, use pins 8 & 9. On Mega, just grab a hardware serialport
SoftwareSerial mySerial(2, 3);
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial);
// On Leonardo/Micro or others with hardware serial, use those! #0 is green wire, #1 is white
//Adafruit_Fingerprint finger = Adafruit_Fingerprint(&Serial1);
void setup()
while (!Serial); // For Yun/Leo/Micro/Zero/...
delay(500);
Serial.println("Adafruit Fingerprint sensor enrollment");
// set the data rate for the sensor serial port
finger.begin(57600);
if (finger.verifyPassword()) {
Serial.println("Found fingerprint sensor!");
} else {
Serial.println("Did not find fingerprint sensor :(");
while (1);
uint8_t readnumber(void) {
uint8_t num = 0;
boolean validnum = false;
while (1) {
while (! Serial.available());
char c = Serial.read();
if (isdigit(c)) {
num *= 10;
num += c - '0';
validnum = true;
} else if (validnum) {
return num;
void loop() // run over and over again
Serial.println("Ready to enroll a fingerprint! Please Type in the ID # you want to save this finger as...");
id = readnumber();
Serial.print("Enrolling ID #");
Serial.println(id);
while (! getFingerprintEnroll() );
uint8_t getFingerprintEnroll() {
int p = -1;
Serial.print("Waiting for valid finger to enroll as #"); Serial.println(id);
while (p != FINGERPRINT_OK) {
p = finger.getImage();
switch (p) {
case FINGERPRINT_OK:
Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
Serial.println(".");
break;
case FINGERPRINT_PACKETRECIEVEERR:
Serial.println("Communication error");
break;
case FINGERPRINT_IMAGEFAIL:
Serial.println("Imaging error");
break;
default:
Serial.println("Unknown error");
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
Serial.print("ID "); Serial.println(id);
p = -1;
Serial.println("Place same finger again");
switch (p) {
break;
Serial.print(".");
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
Serial.print("Creating model for #");
Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
Serial.println("Error writing to flash");
return p;
} else {
return p;
This is a problem with the Arduino compiler. Please downgrade to Arduino 1.6.9
Return to “For Educators”
