Hi there, I'm new in arduino and stepper motor . Basically i setup a bipolar stepper motor on to an arduino uno stack with motor shield kit v2.0 with the help on the tutorial . Can anyone help me on writing a code so that my stepper motor can rotate from 45degree to 90 degree and stop for 5 seconds and then go back to original position ( 45 degree) ?
Thank you
Help, stepper arduino code on motor shield v2.0
- Franklin97355
Re: Help, stepper arduino code on motor shield v2.0
Have you worked with the example code in the motor library? What code do you have now and what does it do? How will you know where the motor is when the program starts?
I've written this code:
#include <Wire.h>
#include <Adafruit_MotorShield.h>
#include "utility/Adafruit_PWMServoDriver.h"
Adafruit_MotorShield AFMS = Adafruit_MotorShield();
Adafruit_StepperMotor *myMotor = AFMS.getStepper(200, 2);
Serial.begin(9600);
AFMS.begin();
Serial.println("Single coil steps");
myMotor->step(50, FORWARD, SINGLE);
but somehow there some problem occurred on my stepper motor.
I've attached a video on a forum , somehow i don't know why i can attached in here.
here it is :
http://forum.arduino.cc/index.php?topic=236745.0
#include <Wire.h>
Serial.begin(9600);
AFMS.begin();
here it is :
What motor are you using? Please post a link to the electrical specifications.
Also, you do not set the speed anywhere in your code. Try running the example code from the library. This code is known to work.
heres the spec of my motor :
http://www.oriental-motor.co.uk/Product ... &dwn=artnr
i did , it's still the same ( with and without setting the speed ) on the this example code :
#include <Wire.h>
// Create the motor shield object with the default I2C address
// Or, create it with a different I2C address (say for stacking)
// Adafruit_MotorShield AFMS = Adafruit_MotorShield(0x61);
// Connect a stepper motor with 200 steps per revolution (1.8 degree)
// to motor port #2 (M3 and M4)
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println("Stepper test!");
AFMS.begin(); // create with the default frequency 1.6KHz
//AFMS.begin(1000); // OR with a different frequency, say 1KHz
myMotor->setSpeed(10); // 10 rpm
myMotor->step(100, FORWARD, SINGLE);
myMotor->step(100, BACKWARD, SINGLE);
Serial.println("Double coil steps");
myMotor->step(100, FORWARD, DOUBLE);
myMotor->step(100, BACKWARD, DOUBLE);
Serial.println("Interleave coil steps");
myMotor->step(100, FORWARD, INTERLEAVE);
myMotor->step(100, BACKWARD, INTERLEAVE);
Serial.println("Microstep steps");
myMotor->step(50, FORWARD, MICROSTEP);
myMotor->step(50, BACKWARD, MICROSTEP);
#include <Wire.h>
There are two problems there:
1) You are trying to run a 2.3v motor on 5v.
2) Even at the rated voltage, the motor will draw too much current for the shield.
The shield is rated for 1.2A/Phase. The motor is rated at 1.5A/Phase @ 2.32 volts. Running it at 5volts, the motor will be trying to pull more than 3A from the shield.
This motor is better suited to a chopper type constant-current motor controller such as the gSheild - https://www.adafruit.com/products/1750
so what can i do besides purchasing a new shield ? cause i'm kinda in need the motor to run smoothly asap , as my fyp due in less than 48 hours. all i want is to make the motor to turn 45 degree and back .
if i've tried using lesser voltage supply , let's say 2AA which is a total of 3V will it work ?
1.2A/phase & 1.5A/phase , the difference is 0.3A , is it a big difference ?
At 3v, the current will be over 1.9A. That is more than 50% over spec. You either need to find a shield compatible with the motor, or a motor compatible with the shield. https://www.adafruit.com/products/324
do u know where can i find a motor with frame size less than 35mm?
Pololu has a few. Here's one:
http://www.pololu.com/product/1205
hi there, i manage to sort my motor. so here my currently code:
#include <Wire.h>
Serial.begin(9600);
AFMS.begin();
myMotor->step(50, BACKWARD, SINGLE);
the motor will turn back and fort since the code is written forward and backward , so if i want it to turn 50 steps and pause for 5 seconds , what code should i add into ?
thanks
#include <Wire.h>
Serial.begin(9600);
AFMS.begin();
thanks
Looks like you already have the 50 forward and 50 reverse. To delay for 5 seconds, add a
delay(5000);
thank you, really appreciate it .
