We do not parts for servos. Try Lynxmotion or Servo City.
http://www.lynxmotion.com/c-75-accessories.aspx
https://www.servocity.com/html/servo_arms___horns.html
Servo control by Flex sensor
- Franklin97355
Re: Servo control by Flex sensor
Try ServoCity. These ServoBlocks are the best I've found. They also carry Actobotics
- spongy918
Thanks buddy!
- spongy918
Dear Admin,
I've brought the Micro servo of MG90S Tower Pro, running a simple code for testing. However, the shaft was being held in a position, no further movements. But its working as replaced by another model of SG92R. Am I something wrong?
main core of simple code:
void loop()
myservo.write(0);
delay(500);
myservo.write(180);
delay(500);
Thank you!
void loop()
myservo.write(0);
delay(500);
myservo.write(180);
delay(500);
Thank you!
Make sure that the cable is plugged in the right way (the yellow wire is the signal wire).
If the servo is not plugged in, can you turn the shaft by hand?
