Hi! I'm trying to use the Gemma for the first time and I cannot upload code to it. This is the link to the code I'm copying for the owl chirp from the Adafruit page: https://learn.adafruit.com/chirping-plu ... other-code
The code is fine, but I'm having problems with the device. This is the message I'm getting when I upload the code: Binary sketch size: 1,132 bytes (of a 5,310 byte maximum)
avrdude: usbdev_open(): did not find any USB device "usb"
I have the USB connected and I have the Gemma device selected. I also have tried different COM ports and I have switched back to make sure the Arduino Uno is working, which it is. Please advise.
Gemma
- adafruit_support_rick
Re: Gemma
Are you pressing the reset button on the Gemma just before the upload begins?
Is the LED pulsing?
Have you tried a different USB cable?
What kind of computer are you using?
If Windows, did you install the USBtinyISP driver?
Does the Gemma show up in Device Manager?
If Mac, does the Gemma show up under USB devices in System Report?
Is the LED pulsing?
- ashleyhaw
Re: Gemma
I have tried 2 USB cables; one is new and I just ordered it from you all.
I pressed the reset. The PWR button is green and the red light comes on when I first push the reset, but that's it. It's not pulsing.
I have a Lenovo with Windows 7. I'm fairly certain that I installed the USBISPtinydriver successfully. I'm wondering why I'm getting a message about the USB. It's my first time using Gemma and I set up the circuit according to the owl guts pack. Do you think something is wrong with my circuit? Would that prompt the message about the USB? Thanks!
- Franklin97355
Re: Gemma
If you have an Arduino Uno you could try this and see if it works. I would disconnect the gemma from the circuit and see if that helps but I would disconnect it if you try to repair the bootloader anyway. If none of this helps please email [email protected] with a link to this thread for a replacement
Re: Gemma
Sounds like the bootloader isn't running. As franklin97355 says, you can try to repair the bootloader, or you can contact [email protected] for a replacement.
The repair instructions are here:
https://learn.adafruit.com/introducing- ... bootloader
- ashleyc
Re: Gemma
I tried this three times with different Gemmas and I still get the same message. Any suggestions? I'm still hoping to do this project with my students this year, but neither the IT person at our school nor I can figure out the solution. Thanks!
Re: Gemma
Can you look for the Gemma in Device Manager? It should appear under "LibUSB - Win32 Devices". If it doesn't appear there, try installing the driver again.
- ashleyc
Re: Gemma
I reinstalled the software and I'm getting the same error message, Binary sketch size: 1,132 bytes (of a 5,310 byte maximum)
avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
I'm really frustrated. I have invested a great deal of time into this project with no success. I really want to do this project with my students, but I don't know what's going wrong. Has anyone else had success using the Gemma with the project?
Thanks.
Thanks.
Re: Gemma
Yes - that's how it appears to Windows.ashleyc wrote:I see "USBtiny" there, not "Gemma".
Are you sure the bootloader is running? The red LED should pulse to 10 seconds after you press the reset button. This indicates that the bootloader is running. The upload must begin while the bootloader is running.ashleyc wrote: avrdude: Error: Could not find USBtiny device (0x1781/0xc9f)
Also, have you tried some different USB cables and USB ports?
Re: Gemma
The bootloader on the Gemma may be corrupted. If you have a Uno, you can repair the bootloader:
- ashleyhaw
Re: Gemma
Hi! I tried to repair the bootloader as advised, and this is the error message I receive:
code.cpp:1:24: error: optiLoader.h: No such file or directory
code.cpp:10: error: expected initializer before '*' token
code.cpp:11: error: 'uint8_t' does not name a type
code.cpp:19: error: 'uint16_t' does not name a type
code.cpp:46: error: expected constructor, destructor, or type conversion before '*' token
- ashleyhaw
Re: Gemma
- ashleyhaw
Re: Gemma
Also, I don't know what this means. What is the serial console at 9600? I cannot figure this out. I have been trying to get the Gemma to work for almost a year now and I would love to use this with my students, but neither I, nor my colleagues can figure it out. I'm trying to do the own sewable activity with the Gemma, but I can't get it to work (see messages above from ashleyc and ashleyhaw, both are from me), so I'm trying to repair the bootloader. Thanks for any advice.
Open up the serial console at 9600 baud and when it tells you do, press the miniature button on the Trinket (or Gemma) or type in G into the serial console and click Send
You should see the following, the fuses, firmware burned and verified! It will take 2 seconds
