Gemma
Franklin97355
Re: Gemma
Post by Franklin97355 »
adafruit_support_rick
Re: Gemma
ashleyhaw wrote:What is the serial console at 9600?
In the Serial Monitor window, there is a dropdown button on the lower right. Set this to 9600
ashleyhaw wrote: Hi! I tried to repair the bootloader as advised, and this is the error message I receive:
code.cpp:1:24: error: optiLoader.h: No such file or directory
code.cpp:10: error: expected initializer before '*' token
code.cpp:11: error: 'uint8_t' does not name a type
code.cpp:19: error: 'uint16_t' does not name a type
code.cpp:46: error: expected constructor, destructor, or type conversion before '*' token
optiloader.h is one of the files that is part of the trinketloader sketch. You need to have it in the same folder as the trinketloader.ino file:
Janefox
Re: Gemma
Post by Janefox »
Hi
The boys at my school in our Makerspace community are making a wearable electronic cuff and I would like to power it with the Gemma and some Smart Neopixels.
Can you recommend a list of materials that we would need for about 10 students?
Also would you recommend the Gemma or Gemma v2?
Jane
Re: Gemma
We don't stock the Gemma v1 anymore, so you'll get the v2.
You might consider getting one of the Gemma Starter Packs to get yourself going
https://www.adafruit.com/products/1657
If you want to wrap the NeoPixels around the cuff, you could get NeoPixel strips and cut them to length. They come in increments of 1 meter.
https://www.adafruit.com/products/1461
https://www.adafruit.com/products/1460
https://www.adafruit.com/products/1506
Or, you could get individual Flora NeoPixels, and sew them to the cuffs with conductive thread
https://www.adafruit.com/products/1260
https://www.adafruit.com/products/1559
If you cut the strips, you will have to solder wires to the individual segments for connection to the Gemma.
You'll also need a battery of some kind. I suggest a small LiPo battery
This is the smallest we have
https://www.adafruit.com/products/1317
This one is a little bigger, but will give you a longer run-time
https://www.adafruit.com/products/1578
You'll need a charger for the batteries:
This is the simplest one we have:
https://www.adafruit.com/products/1304
Return to “For Educators”
