I am using the Adafruit motor controller v1 with a Sainmart Uno board. I am also using Robot C to program. I have two dc motors plugged into M1 & M2 respectively, but cannot get the motors to run correctly. Do I need to use a breadboard to create a motor controller?
Adafruit Motor Controller V1
Re: Adafruit Motor Controller V1
You should be able to connect the motors directly to the shield. If you post photos of the front and back of the shield we can check for any assembly issues.
Thanks for the quick response. Here are some screenshots that might be helpful. I am using Robot C as the programmer but don't how to identify the motors to be read by Robot C.
I need clear photos of the front and back of the shield to check the assembly.
The library is written for the Arduino IDE. I don't know that it has been ported to RobotC.
Thanks for the quick response. I re-installed the Arduino IDE and am able to get one motor to run using the AF_Motor library. What is the declaration to label both motors M1 & M2 in the sketch to run both motors? Also, what pins are running the motors if they are plugged in M1 & M2?
AF_DCMotor motor1(1);
AF_DCMotor motor4(4);
Pin utilization by motor type is detailed here (about 1/3 down the page)Also, what pins are running the motors if they are plugged in M1 & M2?
https://learn.adafruit.com/adafruit-motor-shield/faq
