DS1820B value stored as a variable?
This is a special forum devoted to educators using Adafruit and Arduino products for teaching.
Re: DS1820B value stored as a variable?
Yes. Post the temperatures.
Have you tested that all the leds work? Maybe add a little code to the setup to flash each one as a test.
You will also need some more code to turn off the 'other' leds off
  if (TempF > 100)
    digitalWrite(redled, HIGH);
    digitalWrite(blueled, LOW);
    digitalWrite(whiteled, LOW);
    digitalWrite(pinkled, LOW);
... etc...
crafty184
Post by crafty184 »
Hi Bill,
It works! I figured out I was missing this call to get the temperatures.
  sensors.requestTemperatures();
Once I added that it worked!
And yes, you're right I do need to turn off the other LED's. ;) Thanks SO MUCH for all the help! I'll post a picture of it "in action" once we make more than a MVP.
Chris
Return to “For Educators”
