The led is flashing on pin 13.
Arduino pin 6 is going to neo pixel DIN
5vdc from arduino is going to 5 vdc on the NEO
Ground is from the arduino next to the 5V on the arduino and I jump the ground on a bread board.
I soldered headers on the NEO and plugged it into a breadboard.
I used a multi tester and I am not getting 5v on the other end of the NEO.
No lights. Any ideas.
// NeoPixel Ring simple sketch (c) 2013 Shae Erisson
// released under the GPLv3 license to match the rest of the AdaFruit NeoPixel library
// Which pin on the Arduino is connected to the NeoPixels?
#define PIN 6
int led = 13;
// How many NeoPixels are attached to the Arduino?
#define NUMPIXELS 8
// When we setup the NeoPixel library, we tell it how many pixels, and which pin to use to send signals.
// Note that for older NeoPixel strips you might need to change the third parameter--see the strandtest
// example for more information on possible values.
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int delayval = 500; // delay for half a second
pixels.begin(); // This initializes the NeoPixel library.
pinMode(led, OUTPUT);
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(led, LOW);
// For a set of NeoPixels the first NeoPixel is 0, second is 1, all the way up to the count of pixels minus one.
for(int i=0;i<NUMPIXELS;i++){
// pixels.Color takes RGB values, from 0,0,0 up to 255,255,255
pixels.setPixelColor(i, pixels.Color(255,255,0)); // Moderately bright green color.
pixels.show(); // This sends the updated pixel color to the hardware.
delay(delayval); // Delay for a period of time (in milliseconds).
