Hello!
Our teenagers have built the Piano Glove for a #BlackLivesMatter art + technology teaching activity they are planning.
I understand how the Flora works with the Color Sensor and the RGB LED and can explain this to the youth. However, I am not an expert coder and am finding it difficult to translate how the Flora turns the RGB values into a Tone. I need to be able to do this in simple language.
It looks like it tries to "see" whether the R or G or B value is the highest, then goes on to generate the tone from the highest value. Is that accurate?
If you get me on the right path, I can probably figure out how to read the code from there. . . or if you can point me to the crucial parts of the code to read in order to understand how it translates into tones, that could work too.
Thanks. They have the circuit working (only took three weeks!) but they have questions about the piano tones that I cannot yet answer. . . so glad they are curious.
How does the Piano Glove translate a color into a tone?
- zackboston
Re: How does the Piano Glove translate a color into a tone?
Hello again. Hope you are dug-out from the latest storm!
I think you have the basic idea. But since not all colors are pure primary colors, there is a little extra processing to try to reduce the R, G & B reading into a primary color.
In this bit of code, he determines the lowest of the R, G and B values (remove) and calculates the largest difference in intensity between that and the other two readings (normalize)
The lowest color is subtracted out - since it can't contribute to a 'primary' color.
Then the values are 'normalized' to a value between 0 and 1 for use in selecting a tone.
float remove, normalize;
if ((b < g) && (b < r)) {
remove = b;
normalize = max(r-b, g-b);
else if ((g < b) && (g < r)) {
remove = g;
normalize = max(r-g, b-g);
else {
remove = r;
normalize = max(b-r, g-r);
// get rid of minority report
float rednorm = r - remove;
float greennorm = g - remove;
float bluenorm = b - remove;
// now normalize for the highest number
rednorm /= normalize;
greennorm /= normalize;
bluenorm /= normalize;
