Hello Everyone,
I teach a STEAM course at an international boarding school. I have a student using the FLORA GPS module. However, I'm having some trouble understanding the Adafruit GPS Library. I've looked on the Gethub site and I don't see much documentation about the library.
Specifically my issue is with the command "GPS.latitude". This command appears to concatenate the degrees and minutes of the latitude and then add the seconds as a decimal (converted to base 10). Why are the degrees and minutes concatenated? What does this number represent?
Any advice would be appreciated! Thanks!
- adafruit_support_rick
Re: Adafruit GPS Library
Latitude and longitude both have the same format: (degrees*100) + minutes.
That is the format as received from the GPS itself.
Here's a function to convert the format to decimal degrees:
float ToDecimalDegrees(float formattedLatLon)
float decDegrees = (float)((int)formattedLatLon / 100);
float decMinutes = formattedLatLon - (decDegrees * 100);
float fractDegrees = decMinutes / 60.0;
return decDegrees + fractDegrees;
- mlomuscio
Thanks! It all makes sense to me now!
