Hi! I have successfully connected Fona + Uno, can send and receive SMS , but I do not know how to write code that will allow me to decode the received sms and enable output.
please show me the direction . Thank you!
Need help with programming FONA
- adafruit_support_rick
Re: Need help with programming FONA
You want to parse the SMS messages you receive? What is the format of the messages?
- d32en
Hi! Yes , I want to parse the message and perform an action using output UNO.adafruit_support_rick wrote:You want to parse the SMS messages you receive? What is the format of the messages?
The format of the message may be of the type "OUT 1 ON", "OUT 1 OFF"
OK, so you have your sms message in a buffer. Let's call it smsBuffer.
smsBuffer is a character array containing the SMS message.
You can now use the sscanf function to parse out your message. You have three fields in your message: the command "OUT", the pin number, and the pin value, "ON" or "OFF". sscanf uses a format string to identify the expected fields in a character buffer, and it parses them out to a set of variables. It returns the number of fields it successfully parsed.
In the format string, '%s' means match a string of non-whitespace characters. %d means match a decimal number.
In your code, make sure that numFields is equal to 3 before you proceed with anything.
You can use the strncmp function to check the values of command and cmdValue. strcmp return 0 when its two string arguments match:
char command[4]; //command string
int pin; //pin number
char cmdValue[4]; // value string
int numFields = (smsBuffer, "%s %d %s", command, &pin, cmdValue);
if (3 == numFields)
if (0 == strncmp(command, "OUT", 3))
if (0==strncmp(cmdValue, "ON", 2))
digitalWrite(pin, HIGH);
else
if (0==strncmp(cmdValue, "OFF", 3))
digitalWrite(pin, LOW);
- d32en
adafruit_support_rick wrote:OK, so you have your sms message in a buffer. Let's call it smsBuffer.
In the format string, '%s' means match a string of non-whitespace characters. %d means match a decimal number.Code: Select all
char command[4]; //command string int pin; //pin number char cmdValue[4]; // value string int numFields = (smsBuffer, "%s %d %s", command, &pin, cmdValue);
You can use the strncmp function to check the values of command and cmdValue. strcmp return 0 when its two string arguments match:Code: Select all
if (3 == numFields) { if (0 == strncmp(command, "OUT", 3)) { if (0==strncmp(cmdValue, "ON", 2)) { digitalWrite(pin, HIGH); } else { if (0==strncmp(cmdValue, "OFF", 3)) { digitalWrite(pin, LOW); } } } }
I feel very sorry , but I forgot to say that I am a beginner programmer , very beginner ...
maybe it's blatantly on my part, but you can get the complete code ( at least from a possible ) with an explanation .
And so I am very grateful for the help.
Sorry, but I really can't program your project for you.
- d32en
thanks for the quick help
- d32en
Need help finding errors in the sketch .
Need your help in finding errors in the sketch .
I want to connect FONA + Arduino Uno, the sketch was kindly provided by Adafrtuit.
The process of compiling does not end very long time , what is it please help!
http://ubidots.com/docs/devices/FONA.html
/* Chip McClelland - Cellular Data Logger
BSD license, Please keep my name and the required Adafruit text in any redistribution
This sketch will connect to Ubidots and periodically upload the current temperature and humidity as well as the number
of times a PIR sensor has detected a person. The counts are then reset and you can access the data on your Ubidots account.
IDE: Arduino 1.0 or later
I had to add the following line to the Adafruit_FONA.cpp file: typedef
char PROGMEM prog_char;
Otherwise this code would not compile
Hardware - Adafruit Fona GSM Board
Temperature Sensor - Dummy Code for now
Person Counter - Dummy Code for now
I made use of the Adafruit Fona library and parts of the example code
This is an example for our Adafruit FONA Cellular Module
Designed specifically to work with the Adafruit FONA
----> http://www.adafruit.com/products/1946
----> http://www.adafruit.com/products/1963
products from Adafruit!
This code has been modified Sep 15 2014
by Mateo Vélez - Metavix - for Ubidots Inc.
This code is in the public domain.
#include <HardwareSerial.h>
#include "Adafruit_FONA.h"
#define FONA_RX 1
#define FONA_TX 0
#define FONA_RST 4
#define FONA_KEY 6
#define FONA_PS 7
#define HWSERIAL Serial1
char replybuffer[255];
HardwareSerial fonaSS = Serial1;
Adafruit_FONA fona = Adafruit_FONA(&fonaSS, FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
int Interval = 10000; // Time between measurements in seconds
int KeyTime = 2000; // Time needed to turn on the Fona
unsigned long Reporting = 30000; // Time between uploads to Ubidots
unsigned long TimeOut = 30000; // How long we will give an AT command to comeplete
unsigned long LastReading = 0; // When did we last read the sensors - they are slow so will read between sends
unsigned long LastReporting = 0; // When did we last send data to Ubidots
uint8_t n=0;
int f = 0;
int PersonCount = 0;
delay(3000);
HWSERIAL.begin(4800);
Serial.println("Started setup");
pinMode(FONA_KEY,OUTPUT); // This is the pin used to turn on and off the Fona
TurnOnFona();
Serial.println(F("FONA basic test"));
Serial.println(F("Initializing....(May take 3 seconds)")); // See if the FONA is responding
if (! fona.begin(4800)) { // make it slow so its easy to read!
Serial.println(F("Couldn't find FONA"));
while (1);
GetConnected();
Serial.println(F("FONA is OK"));
TurnOffFona();
Serial.println("in Loop");
delay(2000);
int value = analogRead(A0);
if (LastReporting + Reporting <= millis()) { // This checks to see if it is time to send to Ubidots
TurnOnFona(); // Turn on the module
GetConnected(); // Connect to network and start GPRS
Send2Ubidots(String(value)); // Send data to Ubidots
GetDisconnected(); // Disconnect from GPRS
TurnOffFona(); // Turn off the modeule
LastReporting = millis();
if (LastReading + Interval <= millis()) { // This checks to see if it is time to take a sensor reading
f ++; //Do some math to convert the Celsius to Fahrenheit
PersonCount ++;
Serial.print(F("The current Temperature is: "));
Serial.print(f); //Send the temperature in degrees F to the serial monitor
Serial.print(F("F "));
LastReading = millis(); // Record the time of the last sensor readings
// This function is to send the sensor data to Ubidots - each step is commented in the serial terminal
void Send2ubidots(String value)
int num;
String le;
String var;
var = "{\"value\":"+ value + "}"; //value is the sensor value
num = var.length();
le = String(num); //this is to calcule the length of var
Serial.print(F("Start the connection to Ubidots: "));
if (SendATCommand("AT+CIPSTART=\"tcp\",\"things.ubidots.com",\"80\"",'C','T')) {
Serial.println("Connected");
Serial.print(F("Begin to send data to the remote server: "));
if (SendATCommand("AT+CIPSEND",'\n','>')) {
Serial.println("Sending");
fona.println("POST /api/v1.6/variables/550d213776254253aa33d33c/values HTTP/1.1"); // My ID #
fona.println("Content-Type: application/json");
fona.println("Content-Length: "+le");
fona.println("X-Auth-Token: dGC0eEi6DlJzPEhR22qZKJdrz9Ddr3dXLfFvh8uXQwnHcjmm7HMQesvX2ij0"); // My Ubidots Token #
fona.println("Host: things.ubidots.com");
fona.println();
fona.println(var);
fona.println();
fona.println((char)26); //This ends the JSON SEND with a carriage return
Serial.print(F("Send JSON Package: "));
if (SendATCommand("",'2','0')) { // The 200 code from Ubidots means it was successfully uploaded
Serial.println("Sent");
PersonCount = 0;
else {
Serial.println("Send Timed out, will retry at next interval");
// delay(2000);
Serial.print(F("Close connection to Ubidots: ")); // Close the connection
if (SendATCommand("AT+CIPCLOSE",'G','M')) {
Serial.println("Closed");
boolean SendATCommand(char Command[], char Value1, char Value2) {
unsigned char buffer[64]; // buffer array for data recieve over serial port
int count = 0;
int complete = 0;
unsigned long commandClock = millis(); // Start the timeout clock
fona.println(Command);
while(!complete && commandClock <= millis()+TimeOut) // Need to give the modem time to complete command
while(!fona.available() && commandClock <= millis()+TimeOut);
while(fona.available()) { // reading data into char array
buffer[count++]=fona.read(); // writing data into array
if(count == 64) break;
Serial.write(buffer,count); // Uncomment if needed to debug
for (int i=0; i <= count; i++) {
if(buffer[i]==Value1 && buffer[i+1]==Value2) complete = 1;
if (complete ==1) return 1; // Returns "True" - "False" sticks in the loop for now
else return 0;
void TurnOnFona()
Serial.print("Turning on Fona: ");
while(digitalRead(FONA_PS))
digitalWrite(FONA_KEY,LOW);
unsigned long KeyPress = millis();
while(KeyPress + KeyTime >= millis()) {}
digitalWrite(FONA_KEY,HIGH);
fona.begin(4800);
Serial.println("success!");
void GetConnected()
do
n = fona.getNetworkStatus(); // Read the Network / Cellular Status
Serial.print(F("Network status "));
Serial.print(n);
Serial.print(F(": "));
if (n == 0) Serial.println(F("Not registered"));
if (n == 1) Serial.println(F("Registered (home)"));
if (n == 2) Serial.println(F("Not registered (searching)"));
if (n == 3) Serial.println(F("Denied"));
if (n == 4) Serial.println(F("Unknown"));
if (n == 5) Serial.println(F("Registered roaming"));
} while (n != 1);
void GetDisconnected()
fona.enableGPRS(false);
Serial.println(F("GPRS Serivces Started"));
void TurnOffFona()
Serial.print("Turning off Fona: ");
Wow - what a mess. Fist of all, that sketch is using an outdated version of the FONA library. Second, it's not written for a Uno - it's written for a Leonardo or a Mega. Third, it had several syntax errors. I presume I fixed them correctly.
Anyway, this version of the sketch at least compiles. You will have to connect FONA TX to Uno pin 2, and FONA RX to Uno pin 3:
#include <SoftwareSerial.h>
#define FONA_RX 1
#define FONA_TX 0
#define FONA_RST 4
#define FONA_KEY 6
#define FONA_PS 7
//#define HWSERIAL Serial1
SoftwareSerial fonaSS = SoftwareSerial(2,3);
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
uint8_t n=0;
int f = 0;
delay(3000);
fonaSS.begin(4800);
TurnOnFona();
if (! fona.begin(fonaSS)) { // make it slow so its easy to read!
while (1);
GetConnected();
TurnOffFona();
delay(2000);
Send2ubidots(String(value)); // Send data to Ubidots
PersonCount ++;
int num;
String le;
String var;
num = var.length();
if (SendATCommand("AT+CIPSTART=\"tcp\",\"things.ubidots.com\",\"80\"",'C','T')) {
fona.print("Content-Length: "); fona.println(le);
fona.println();
fona.println(var);
fona.println();
PersonCount = 0;
else {
// delay(2000);
int count = 0;
int complete = 0;
else return 0;
void TurnOnFona()
fona.begin(fonaSS);
void GetConnected()
do
Serial.print(n);
} while (n != 1);
void TurnOffFona()
