We purchased 3 Gemma 2s.
Using Windows 8.1.
We downloaded the Arduino 1.6.xIDE with Adafruit Board .
https://learn.adafruit.com/adafruit-ard ... ot-6-x-ide
We also download the drivers.
https://learn.adafruit.com/usbtinyisp/drivers
Rebooted and Arduino does not see the Gemma 2 in Tools>Ports
We would really like to use Centos 7 Linux.
Please throw us a bone.
gemma2 not being recongnized Arduino 1.6.1[solved]
- 1885
- Franklin97355
Re: gemma2 not being recongnized by Arduino-16.x IDE
Do you mean tools>boardsRebooted and Arduino does not see the Gemma 2 in Tools>Ports
- 1885
I do mean Tools>Ports
I can select Tools>Boards>Arduino Gemma 8MHz
I just assumed the Gemma would show up in Ports like my Uno and Mega.
I have tried Linux, Mac OSX 7.6 and Windows 8.1 with 2 different Gemmas with no luck.
I set the /etc/udev/rules.d/ up . Linux I get this error: arduino-1.6.1/hardware/tools/avr/bin/avrdude: error while loading shared libraries: libtinfo.so.5: cannot open shared object file: No such file or directory
Window 8.1 avrdude does not see the device.
OSx 7.6 does not how andything under Tools>Ports
I downloaded the Arduinio IDE for Flora (I have two of these) Gemma. Linux, OSX and Win 8.1
I also tried to install the drivers Window 8.1 for USBtiny.
I'm not doing something right.
I am connecting the Gemma directly into a USB. Do I need the USBTiny Programmer?
cwc
cwc
- Franklin97355
- 1885
Do I need arvdude installed on my Linux Box?
Followed the directions.
I am trying using Centos 7. Added /etc/udev/rules.d/
$ more /etc/udev/rules.d/adafruit-trinket.rules
# udev rule to make Trinket/Pro Trinket/Gemma/Flora programmable without running
Arduino as root.
# Tested with Ubuntu 14.04 and 12.04. Other distributions might need to update
GROUP="dialout"
# to another group value like "users".
# Copy this file to the location of your distribution's udev rules, for example
on Ubuntu:
# sudo cp adafruit-trinket.rules /etc/udev/rules.d/
# Then reload udev configuration by executing:
# sudo reload udev
SUBSYSTEM=="usb", ATTR{idProduct}=="0c9f", ATTRS{idVendor}=="1781", MODE="0660",
GROUP="dialout"
[cwc@vita ~]$
This user is in dialout .
$ groups
cwc wheel dialout wireshark
Error:
avrdude: error: usbtiny_transmit: Input/output error
this check.
Arduino as root.
GROUP="dialout"
on Ubuntu:
# sudo reload udev
GROUP="dialout"
[cwc@vita ~]$
$ groups
Error:
this check.
- adafruit2
gemma does not show up under Ports, it does not have a usb-serial converter. you can try turning on 'verbose uploads' (prefs box in Arduino IDE) and paste in the output
- 1885
Re: gemma2 not being recongnized Arduino 1.6.1[solved]
Solved.
I ignored the errors and got the Gemma to work with Neo-Pixels (Epic!)
Setup:
- Centos 7. Added code to udev
[root@vita ~]# more /etc/udev/rules.d/
20-crystalhd.rules adafruit-trinket.rules
70-persistent-ipoib.rules
[root@vita ~]# more /etc/udev/rules.d/adafruit-trinket.rules
Arduino as root.
GROUP="dialout"
on Ubuntu:
# sudo reload udev
GROUP="dialout"
## end of rule.d code
- Made sure to add user to the dialout group.
- Used Arduino IDE 1.6.1 downloaded from Adafruit .
- I really like the way Arduino works with Centos 7
- To run Arduino IDE I decompress the IDE in my home directory and issued the following command from a non-root user:
$/home/your_user_name/arduino-1.6.1/arduino
Thanks for all the help Adafruit.
Setup:
Arduino as root.
GROUP="dialout"
on Ubuntu:
# sudo reload udev
GROUP="dialout"
- adafruit2
