Hi, I purchased a Flora main board and got it several weeks ago and I really need help to solve this problem. When I click upload on Arduino 1.6.4. An error message appears. I copied the error message (shown under):
Sketch uses 4,242 bytes (14%) of program storage space. Maximum is 28,672 bytes.
Global variables use 151 bytes of dynamic memory.
processing.app.debug.RunnerException: Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at cc.arduino.packages.uploaders.SerialUploader.waitForUploadPort(SerialUploader.java:234)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:130)
at processing.app.debug.Compiler.upload(Compiler.java:163)
at processing.app.Sketch.upload(Sketch.java:1220)
at processing.app.Sketch.exportApplet(Sketch.java:1194)
at processing.app.Sketch.exportApplet(Sketch.java:1166)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2487)
at java.lang.Thread.run(Thread.java:745)
Thank you.
Flora main board problem
- adafruit_support_rick
Re: Flora main board problem
Is this windows or mac? Are you sure you have the correct port selected? Do you have Flora selected as the board type?
Have you tried pressing reset on the Flora before the upload begins?
Does the red LED pulse on the Flora when you press the reset button?
Is the green LED lit on the Flora?
