// Libraries
#include <Adafruit_CC3000.h>
#include <SPI.h>
#include "DHT.h"
#include <avr/wdt.h>
// Define CC3000 chip pins
#define ADAFRUIT_CC3000_IRQ 3
#define ADAFRUIT_CC3000_VBAT 5
#define ADAFRUIT_CC3000_CS 10
// DHT sensor
#define DHTPIN 7
#define DHTTYPE DHT22
// Create CC3000 instances
Adafruit_CC3000 cc3000 = Adafruit_CC3000(ADAFRUIT_CC3000_CS,
ADAFRUIT_CC3000_IRQ, ADAFRUIT_CC3000_VBAT, SPI_CLOCK_DIV2);
// DHT instance
DHT dht(DHTPIN, DHTTYPE);
// WLAN parameters
#define WLAN_SSID "myNetwork"
#define WLAN_PASS "routerPassword"
#define WLAN_SECURITY WLAN_SEC_WPA2
// Dweet parameters
#define thing_name "HSS_CodeKids"
// Variables to be sent
int temperature;
int humidity;
int light;
const int splSensor = A3;
uint32_t ip;
void setup(void)
// Initialize
Serial.begin(115200);
Serial.println(F("\nInitializing..."));
if (!cc3000.begin())
Serial.println(F("Couldn't begin()! Check your wiring?"));
while(1);
// Connect to WiFi network
Serial.print(F("Connecting to WiFi network ..."));
cc3000.connectToAP(WLAN_SSID, WLAN_PASS, WLAN_SECURITY);
Serial.println(F("done!"));
/* Wait for DHCP to complete */
Serial.println(F("Request DHCP"));
while (!cc3000.checkDHCP())
delay(100);
void loop(void)
// Measure from DHT
float t = dht.readTemperature();
float h = dht.readHumidity();
temperature = (int)t;
humidity = (int)h;
// Measure light level
float sensor_reading = analogRead(A0);
light = (int)(sensor_reading/1024*100);
Serial.println(F("Measurements done"));
//measure from sound sensor that reid installed
// the SPL output is connected to analog pin 3
Serial.println(analogRead(splSensor), DEC);
delay(200); // delay to avoid overloading the serial port buffer
// Start watchdog
wdt_enable(WDTO_8S);
// Get IP
uint32_t ip = 0;
Serial.print(F("www.dweet.io -> "));
while (ip == 0) {
if (! cc3000.getHostByName("www.dweet.io", &ip)) {
Serial.println(F("Couldn't resolve!"));
delay(500);
cc3000.printIPdotsRev(ip);
Serial.println(F(""));
// Reset watchdog
wdt_reset();
// Check connection to WiFi
Serial.print(F("Checking WiFi connection ..."));
if(!cc3000.checkConnected()){while(1){}}
Serial.println(F("done."));
wdt_reset();
// Send request
Adafruit_CC3000_Client client = cc3000.connectTCP(ip, 80);
if (client.connected()) {
Serial.print(F("Sending request... "));
client.fastrprint(F("GET /dweet/for/"));
client.print(thing_name);
client.fastrprint(F("?temperature="));
client.print(temperature);
client.fastrprint(F("&humidity="));
client.print(humidity);
client.fastrprint(F("&light="));
client.print(light);
client.fastrprintln(F(" HTTP/1.1"));
client.fastrprintln(F("Host: dweet.io"));
client.fastrprintln(F("Connection: close"));
client.fastrprintln(F(""));
} else {
Serial.println(F("Connection failed"));
return;
// Reset watchdog
wdt_reset();
Serial.println(F("Reading answer..."));
while (client.connected()) {
while (client.available()) {
char c = client.read();
Serial.print(c);
// Reset watchdog
wdt_reset();
// Close connection and disconnect
client.close();
Serial.println(F("Closing connection"));
// Reset watchdog & disable
wdt_reset();
wdt_disable();
// Wait 60 seconds until next update
wait(60000);
// Wait for a given time using the watchdog
void wait(int total_delay) {
int number_steps = (int)(total_delay/5000);
for (int i = 0; i < number_steps; i++){
//Serial.println(F("Waiting for 5 seconds ..."));
delay(5000);
wdt_reset();
wdt_disable();
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h>
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10085);
void setup(void)
Serial.begin(9600);
Serial.println("Pressure Sensor Test"); Serial.println("");
/* Initialise the sensor */
if(!bmp.begin())
/* There was a problem detecting the BMP085 ... check your connections */
Serial.print("Ooops, no BMP085 detected ... Check your wiring or I2C ADDR!");
while(1);
void loop(void)
/* Get a new sensor event */
sensors_event_t event;
bmp.getEvent(&event);
/* Display the results (barometric pressure is measure in hPa) */
if (event.pressure)
/* Display atmospheric pressure in hPa */
Serial.print("Pressure: "); Serial.print(event.pressure); Serial.println(" hPa");
else
Serial.println("Sensor error");
delay(250);
