I posted on December 8 about an H-bridge for motor control. I have since ordered the recommended part DRV8835 from pololu and hooked it up to the gemma (see attached diagram and code) but it does not work. Help? I am assuming something is incompatible with something, but I have no idea what. Again the motors come in kits designed for 1.5 volts, but I've been running them at 3 no problem.
I double checked all the connections. I did notice the battery pack getting warm...the H-bridge was not.
As dictated by the specs (https://www.pololu.com/product/2512), pins 0 and 1 of the gemma are wired to pins 8 and 10 of the H-bridge.
Controlling two motors with one gemma
- pmidthun
- Arduino program for two motors.png (83.38 KiB) Viewed 381 times
- Fritzing diagram for 2 motors.png (142.97 KiB) Viewed 381 times
Re: Controlling two motors with one gemma
Pololu should be able to help you with the wiring for this. I believe that you need to provide power for the logic as well as for the motors.
- Franklin97355
You need power to the Gemma and at least a ground between the Gemma and the controller board.
- pmidthun
Thanks, that sent me down the right path. Turns out I didn't realize the H-bridge component still needs to be powered separately from the motors' power source coming in to it. Once I had power and ground for both the motors and the H-bridge component wired to the component it worked as intended. Makes sense in retrospect, but somehow didn't compute at the time.
