using connman to setup wifi
Talk about Beagle Bone & Adafruit Beagle Bone products!
Postby kinetic_ion » Mon Jun 25, 2012 1:42 am
I am attempting to install the usb wifi adapter from the adafruit store with some progress. I followed the beaglebone usb wifi tutorial on ladyada and have completed every step successfully up to part where I have to create files in the connman folder.
I didn't have a file called "settings" in /var/lib/connman folder so I created one using nano.
nano /var/lib/connman/settings
Contents of 'settings':
[global]
OfflineMode=false
[WiFi]
Enable=true
[Bluetooth]
Enable=false
[Wired]
Enable=true
[3G]
Enable=false
[WiMAX] Enable=false
I also created a new file called "wifi.config" in the same folder.
nano /var/lib/connman/wifi.config
Contents of 'wifi.config':
[service_home]
Type=wifi
Name=MyNetworkNameCaseSeNSiTivE
Security=wpa
Passphrase=MyCaseSenSitivEPassWord
I then reset the connman
sytemctl restart connman.services
I seem to not connect after using ifconfig wlan0.
Any idea what I can do next? I am connecting to a BB Rev A3 and using Terminal in Mac OSX.
kinetic_ion
Re: using connman to setup wifi
Postby adafruit » Mon Jun 25, 2012 8:41 pm
A3 is fairly old - we've only tested the wifi with A5 - can you burn a new SD card with the latest boot image? You may need a later kernel :(
Postby kinetic_ion » Thu Jun 28, 2012 2:02 am
Ok I got it working after updating to Angstrom v2012.05 - Kernel 3.2.18
kinetic_ion
Postby DannyX » Fri Jun 29, 2012 10:01 pm
I am having a very similar problem which I believe maybe down to the fact I'm running kernel 3.2.14, is there a way to upgrade the kernel without having to reimage the sd card?
DannyX
Postby tgalonso » Sun Jul 01, 2012 9:58 pm
if you have a working ethernet connected to the internet do:
opkg update
opkg upgrade
caution it takes hours!
tgalonso
tgalonso
Return to Beagle Bone & Adafruit Beagle Bone products
Users browsing this forum: Bymbomietty, mibignistinly and 1 guest
New Products [108]
More Dev Boards[31]
Breakout Boards[34]
Components & Parts[70]
LEDs[111]
Cables[62]
