BBB does not appear as USB device
by wcritchie on Thu Jun 20, 2013 5:58 am
Brand new BBB, followed directions to connect USB and install Mac drivers. BBB does not show up as a USB drive (or at all) and browsing to 192.168.7.2 times out.
I've tried:
- reflashing several times
- connected to Windows machine
- different mini-usb cable
- booted Angstrom from microSD card
The board works; when HDMI monitor and keyboard/mouse is connected, the desktop runs just fine.
Anything else to try or should I request an RMA?
Thanks for any ideas.
wcritchie
Re: BBB does not appear as USB device
by adafruit_support_mike on Thu Jun 20, 2013 9:53 pm
What operating system are you using, and have you installed the appropriate drivers?
by wcritchie on Fri Jun 21, 2013 6:02 am
Mac OS X 10.8.4 w/ HoRNDIS Rel 4 and FDTI_Ser installed. Also tried on a window XP machine with the required drivers installed.
wcritchie
by adafruit_support_mike on Fri Jun 21, 2013 7:42 pm
That sounds like a possible problem with the USB hardware.
Check the support forums for the BB: http://beagleboard.org/Support/Hardware%20Support , and if you can't find anything there, you'll need to do an RMA through the official channels: http://beagleboard.org/Support/RMA . They're strict about that.
