BeagleBone Wifi tutorial
Talk about Beagle Bone & Adafruit Beagle Bone products!
Postby Plecharts » Mon May 14, 2012 10:14 am
Hi, I really like the Wi-Fi tutorial for the BeagleBone ( http://ladyada.net/products/beaglebone/wifi.html ), but I have a question: Is it possible to configure BeagleBone to be able to connect to two or more access points instead of just one?
Thank You
Plecharts
Plecharts
Re: BeagleBone Wifi tutorial
Postby adafruit » Mon May 14, 2012 8:13 pm
do you mean at the same time (bridging) or for it to have multiple options for connecting and it picks them by priority?
Postby Plecharts » Tue May 15, 2012 12:19 am
I mean to have multiple options and select between them automatically.
Plecharts
Postby adafruit » Tue May 15, 2012 10:25 am
that would be something the connection manager can do - we haven't played much with it but you could try reading about it here
http://connman.net/
Postby keener » Mon Jun 18, 2012 9:00 am
it looks like the helpful instructions provided here http://ladyada.net/products/beaglebone/wifi.html does not work with connman 0.79 (that is the version currently provided by angstrom repository).
According to this http://connman.net/blogs/patrik/2012/connman-079 , they have made some changes property names,... starting at version 0.79
I have not been able to make wifi to work with connman 0.79
keener
Postby adafruit » Mon Jun 18, 2012 9:50 am
The tutorial we have is for the stock Bone distribution - if/when the Bone distro is updated we'll try and update the tutorial to match. Until then we suggest getting the stock distro
Postby HughJohnson » Mon Jun 18, 2012 10:28 am
I went through the tutorial and I had one issue; connman only seems to support one type of connection at a time, so I could never connect to wifi with the ethernet still attached. After removing the ethernet cable wifi just worked perfectly using the tutorial.
Life is what you make.
HughJohnson
Return to Beagle Bone & Adafruit Beagle Bone products
New Products [103]
LEDs[109]
Cables[61]
