Beagle Wifi Adapter
tgalonso
Re: Beagle Wifi Adapter
Post by tgalonso »
Well I finally got it running! Here is the recipe:
1) start with the A6 image
2) run opkg update and then opkg upgrade twice or setup a temp directory under /home/root and run opkg upgrade with it so that it doesn't run out of space. I stumbled onto the first technique last night, the second one comes from the previous posting which I found today after a late night finding the first one. Oh well!
3) follow the Adafruit tutorial. I used psk instead of wpa.
4) make sure that you unplug the Ethernet cable before rebooting
5) the antenna in the adapter is too small and you have to be close to your wifi router for it to work.
Adafruit you should update the tutorial. I would put my step 2 in the general setup section though. The rest could be added to the wifi section.
Thanks to all the folks in the forum for the help,
Tgalonso
engineerbynight
Post by engineerbynight »
Wow! That did it for me... all is working great now. Thanks!
Now I just need to find a few examples of what I can do, now that I'm online :D
Post by adafruit »
thanks, thats a strange one - we've updated the tutorial page to note that a directory should be made
engineerbynight
FYI... I didn't make a directory... I just reran the update, and tried everything again. Magic.
dogsop
Post by dogsop »
I followed the tutorial exactly, it didn't work. I tested the adapter on my PC and it worked perfectly.
I don't think this adapter is compatible with the Beaglebone at all. :(
tgalonso
Post by tgalonso »
see my posting above, do those upgrade steps before you do the tutorial
tgalonso
AsH83
Post by AsH83 »
@tgalonso
when you ran "opkg update and then opkg upgrade" did your PC stop seeing the board as USB drive? I remember when I tried this before my board stopped showing itself as flash drive?
Anyways I am desperate now to get this wifi to work so i will give it a try? because I followed the instructions as of July 24th and they did not work!!! sometime i see wlan0 with no IP and randomly it goes away then also randomly ifconfig stops responding.
my plan is to:
- start with a fresh image on A6 with the latest 6/18/12 image from Angstrom
- plug Ethernet cable, DC supply and usb cable for serial access.
- create temp folder.
- run update
- run upgrade on the folder.
- follow the instructions again and make sure to unplug the Ethernet cable as you mentioned.
AsH83
Post by AsH83 »
so still same problem: I do see the wifi adapter with dmesg but ifconfig sometime hangs:
root@beaglebone:~# dmesg | tail -6
[ 9.808044] rtlwifi: rx_max_size 15360, rx_urb_num 8, in_ep 1
[ 9.848937] ieee80211 phy0: Selected rate control algorithm 'rtl_rc'
[ 9.849975] usbcore: registered new interface driver rtl8192cu
[ 9.902923] rtl8192cu: MAC auto ON okay!
[ 9.948150] rtl8192cu: Tx queue select: 0x05
[ 9.949554] rtl8192c_common: Loading firmware file rtlwifi/rtl8192cufw.bin
root@beaglebone:~# ifconfig
dougkirk
Post by dougkirk »
Make sure you unplug the Ethernet cable from the bone when resetting; it won't run both wifi and wired ethernet at the same time.
As others have stated, also make sure you're booting from the latest image (from May '12). I have rev A3 but put the latest image onto a 8G micro SD (4G is required). After that, then do 'opkg update' and 'opkg upgrade'. IIRC, 'ifconfig' froze for me before the update and upgrade, but not after.
Finally, proceed with the steps in the tutorial, unplug the Ethernet cable and reset the bone with the wifi adapter plugged in.
I used CoolTerm over the USB connection until these steps were done. (I did connect wired Ethernet once to check it was working, but then went back to serial over USB)
Cheers!
AsH83
Post by AsH83 »
I did opkg update and opkg upgrade with temp folder..
The wifi works sometimes but if i leave it for 45 minutes or so i get an error in the logs about some task got hung.. I will try tonight to redo the steps with no temp folder.
and yes i did unplug my Ethernet cable.
Return to “Beagle Bone & Adafruit Beagle Bone products”
