BeagleBone WIFI connected, but lags; Is issue connman vs. wpa_supplicant?
by ow3n on Fri Jul 06, 2012 12:33 am
I'm using the WIFI adapter from the Adafruit store and after some trial an error have had some success getting connected.
My problem is when I'm connected via WIFI the data is very slow and/or it lags. For example, I can type # ls in the command line and it might take 10 seconds to return. Sometimes it is so slow I can't even see the characters I type.
1. Ethernet connection is still fast
2. Device (also purchased at Adafruit :-) Linux beaglebone 3.2.21 #1 Wed Jul 4 07:53:54 CEST 2012 armv7l GNU/Linux
3. This is a fresh image downloaded and installed yesterday
4. I was able to connect using wpa_supplicant via instructions on this page:
5. Here are the results of various reports [ ifconfig, iwconfig, connman/wifi.config and wpa_supplicant.conf, ping (from the board), ping (to the board) ]
Any advice is appreciated.
# ifconfig
eth0      Link encap:Ethernet  HWaddr D4:94:A1:53:0B:CB
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:  Mask:
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:17 errors:0 dropped:0 overruns:0 frame:0
          TX packets:17 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1464 (1.4 KiB)  TX bytes:1464 (1.4 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:9E:95:9B:52:73
          inet addr:  Bcast:  Mask:
          inet6 addr: fe80::29e:95ff:fe9b:5273/64 Scope:Link
          RX packets:366 errors:0 dropped:0 overruns:0 frame:0
          TX packets:236 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:71764 (70.0 KiB)  TX bytes:40099 (39.1 KiB
# iwconfig
lo        no wireless extensions.
wlan0     IEEE 802.11bgn  ESSID:"crockpot"
          Mode:Managed  Frequency:2.437 GHz  Access Point: 00:18:F8:75:36:6E
          Bit Rate=54 Mb/s   Tx-Power=20 dBm
          Retry  long limit:7   RTS thr=2347 B   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=56/70  Signal level=-54 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:5   Missed beacon:0
eth0      no wireless extensions.
cat /var/lib/connman/wifi.config
Type = wifi
Name = crockpot
Security = wpa2
Passphrase = PASSWORD
# cat /etc/wpa_supplicant.conf
        pairwise=CCMP TKIP
# cat /etc/network/interfaces
auto wlan0
iface wlan0 inet dhcp
    wpa-conf /etc/wpa_supplicant.conf
    wpa-driver wext
ifconfig shows no errors or dropped data, yet if I ping from or to the device I get some very strange results with data lag and data loss.
# ping
PING ( 56(84) bytes of data.
64 bytes from ( icmp_req=1 ttl=52 time=21.7 ms
64 bytes from ( icmp_req=2 ttl=52 time=326 ms
64 bytes from ( icmp_req=3 ttl=52 time=35.4 ms
64 bytes from ( icmp_req=4 ttl=52 time=35.3 ms
64 bytes from ( icmp_req=5 ttl=52 time=1932 ms
64 bytes from ( icmp_req=6 ttl=52 time=4918 ms
64 bytes from ( icmp_req=7 ttl=52 time=18.5 ms
64 bytes from ( icmp_req=8 ttl=52 time=2065 ms
64 bytes from ( icmp_req=9 ttl=52 time=1063 ms
64 bytes from ( icmp_req=10 ttl=52 time=54.4 ms
64 bytes from ( icmp_req=11 ttl=52 time=23.0 ms
64 bytes from ( icmp_req=13 ttl=52 time=1187 ms
64 bytes from ( icmp_req=14 ttl=52 time=188 ms
64 bytes from ( icmp_req=12 ttl=52 time=2198 ms
64 bytes from ( icmp_req=15 ttl=52 time=32.2 ms
64 bytes from ( icmp_req=17 ttl=52 time=2009 ms
64 bytes from ( icmp_req=18 ttl=52 time=1013 ms
64 bytes from ( icmp_req=19 ttl=52 time=36.6 ms
--- ping statistics ---
28 packets transmitted, 18 received, 35% packet loss, time 48949ms
rtt min/avg/max/mdev = 18.532/953.439/4918.332/1256.541 ms, pipe 4
# ping
PING ( 56 data bytes
Request timeout for icmp_seq 0
Request timeout for icmp_seq 1
64 bytes from icmp_seq=0 ttl=64 time=2774.871 ms
64 bytes from icmp_seq=1 ttl=64 time=1773.761 ms
64 bytes from icmp_seq=2 ttl=64 time=772.670 ms
64 bytes from icmp_seq=3 ttl=64 time=1614.361 ms
64 bytes from icmp_seq=4 ttl=64 time=613.129 ms
64 bytes from icmp_seq=5 ttl=64 time=7.516 ms
64 bytes from icmp_seq=6 ttl=64 time=351.276 ms
64 bytes from icmp_seq=7 ttl=64 time=681.398 ms
Request timeout for icmp_seq 10
Request timeout for icmp_seq 11
Request timeout for icmp_seq 12
Request timeout for icmp_seq 13
Request timeout for icmp_seq 14
Request timeout for icmp_seq 15
Request timeout for icmp_seq 16
64 bytes from icmp_seq=8 ttl=64 time=9613.895 ms
64 bytes from icmp_seq=9 ttl=64 time=8613.450 ms
64 bytes from icmp_seq=10 ttl=64 time=7612.495 ms
64 bytes from icmp_seq=11 ttl=64 time=6612.247 ms
64 bytes from icmp_seq=12 ttl=64 time=5611.178 ms
64 bytes from icmp_seq=14 ttl=64 time=3610.000 ms
64 bytes from icmp_seq=15 ttl=64 time=2609.545 ms
64 bytes from icmp_seq=16 ttl=64 time=1611.860 ms
64 bytes from icmp_seq=17 ttl=64 time=610.642 ms
64 bytes from icmp_seq=18 ttl=64 time=4.636 ms
64 bytes from icmp_seq=19 ttl=64 time=8638.493 ms
64 bytes from icmp_seq=20 ttl=64 time=7637.885 ms
64 bytes from icmp_seq=21 ttl=64 time=6636.850 ms
64 bytes from icmp_seq=22 ttl=64 time=5635.772 ms
64 bytes from icmp_seq=23 ttl=64 time=4634.756 ms
64 bytes from icmp_seq=24 ttl=64 time=3633.674 ms
64 bytes from icmp_seq=25 ttl=64 time=2633.247 ms
64 bytes from icmp_seq=26 ttl=64 time=1632.436 ms
64 bytes from icmp_seq=27 ttl=64 time=631.354 ms
64 bytes from icmp_seq=28 ttl=64 time=140.823 ms
29 packets transmitted, 28 packets received, 3.4% packet loss
round-trip min/avg/max/stddev = 4.636/3462.651/9613.895/3019.906 ms
Re: BeagleBone WIFI connected, but lags; Is issue connman vs. wpa_supplicant?
by JakeJake on Mon Jul 09, 2012 3:44 pm
I was using the Adafruit WiFi adapter with my BeagleBone briefly last weekend. The device was very sensitive to be distant from the WiFi router. If I was close to the router with it performance was just OK. If I got far away the connection wouldn't drop, but it would slow to an unusable state.
