serial-USB/JTAG no longer working
by JakeJake on Mon Jul 09, 2012 9:58 am
I received my BeagleBone and started using it this weekend. The serial-USB/JTAG capability appears to have failed in the first 24 hours.
I can still connect to it with "ssh root@beaglebone.local" and once I eject the USB card from my desktop, I can "ssh root@192.168.7.2", but that is it.
The serial communications worked for a while from multiple computers in my home, i.e. "screen /dev/tty.usbserial-TIVIANA4B 115200" but now they do not. I Google searched all day Sunday looking for a solution and nothing worked. I believe the JTAG/USB chip has failed.
JakeJake
Re: serial-USB/JTAG no longer working
by adafruit on Mon Jul 09, 2012 10:56 am
Hi thats a little unusual. If you plug it in to your linux computer, what does your computer's dmesg say?
by JakeJake on Mon Jul 09, 2012 11:39 am
Plugging the Beaglebone into the USB port of my Ubunut Linux, then booting Linux, here is the dmesg output:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 3.2.0-23-generic-pae (buildd@palmer) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu4) ) #36-Ubuntu SMP Tue Apr 10 22:19:09 UTC 2012 (Ubuntu 3.2.0-23.36-generic-pae 3.2.14)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000009fff0000 (usable)
[ 0.000000] BIOS-e820: 000000009fff0000 - 00000000a0000000 (ACPI data)
[ 0.000000] BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] DMI 2.5 present.
[ 0.000000] DMI: innotek GmbH VirtualBox, BIOS VirtualBox 12/01/2006
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] last_pfn = 0x9fff0 max_arch_pfn = 0x1000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR variable ranges disabled:
[ 0.000000] x86 PAT enabled: cpu 0, old 0x7040600070406, new 0x7010600070106
[ 0.000000] CPU MTRRs all blank - virtualized system.
[ 0.000000] initial memory mapped : 0 - 02000000
[ 0.000000] Base memory trampoline at [c009b000] 9b000 size 16384
[ 0.000000] init_memory_mapping: 0000000000000000-0000000037bfe000
[ 0.000000] 0000000000 - 0000200000 page 4k
[ 0.000000] 0000200000 - 0037a00000 page 2M
[ 0.000000] 0037a00000 - 0037bfe000 page 4k
[ 0.000000] kernel direct mapping tables up to 37bfe000 @ 1ffb000-2000000
[ 0.000000] RAMDISK: 364fe000 - 37277000
[ 0.000000] ACPI: RSDP 000e0000 00024 (v02 VBOX )
[ 0.000000] ACPI: XSDT 9fff0030 00034 (v01 VBOX VBOXXSDT 00000001 ASL 00000061)
[ 0.000000] ACPI: FACP 9fff00f0 000F4 (v04 VBOX VBOXFACP 00000001 ASL 00000061)
[ 0.000000] ACPI: DSDT 9fff0410 01B96 (v01 VBOX VBOXBIOS 00000002 INTL 20100528)
[ 0.000000] ACPI: FACS 9fff0200 00040
[ 0.000000] ACPI: SSDT 9fff0240 001CC (v01 VBOX VBOXCPUT 00000002 INTL 20100528)
[ 0.000000] 1667MB HIGHMEM available.
[ 0.000000] 891MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 37bfe000
[ 0.000000] low ram: 0 - 37bfe000
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x00037bfe
[ 0.000000] HighMem 0x00037bfe -> 0x0009fff0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x0009fff0
[ 0.000000] On node 0 totalpages: 655231
[ 0.000000] free_area_init_node: node 0, pgdat c186b480, node_mem_map f50fe200
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3951 pages, LIFO batch:0
[ 0.000000] Normal zone: 1752 pages used for memmap
[ 0.000000] Normal zone: 222502 pages, LIFO batch:31
[ 0.000000] HighMem zone: 3336 pages used for memmap
[ 0.000000] HighMem zone: 423658 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Found and enabled local APIC!
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000f0000
[ 0.000000] PM: Registered nosave memory: 00000000000f0000 - 0000000000100000
[ 0.000000] Allocating PCI resources starting at a0000000 (gap: a0000000:5ffc0000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 14 pages/cpu @f7800000 s34240 r0 d23104 u2097152
[ 0.000000] pcpu-alloc: s34240 r0 d23104 u2097152 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 650111
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-3.2.0-23-generic-pae root=UUID=dff26bd4-23af-4a30-b338-f99ec4e76b09 ro quiet splash vt.handoff=7
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 10485248 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00037bfe:0009fff0)
[ 0.000000] Memory: 2565124k/2621376k available (5825k kernel code, 55800k reserved, 2850k data, 740k init, 1707976k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff16000 - 0xfffff000 ( 932 kB)
[ 0.000000] pkmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xf83fe000 - 0xffbfe000 ( 120 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf7bfe000 ( 891 MB)
[ 0.000000] .init : 0xc1879000 - 0xc1932000 ( 740 kB)
[ 0.000000] .data : 0xc15b04bc - 0xc1878d00 (2850 kB)
[ 0.000000] .text : 0xc1000000 - 0xc15b04bc (5825 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:2304 nr_irqs:256 16
[ 0.000000] CPU 0 irqstacks, hard=f7408000 soft=f740a000
[ 0.000000] vt handoff: transparent VT on vt#7
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration failed
[ 0.000000] TSC: Unable to calibrate against PIT
[ 0.000000] TSC: using PMTIMER reference calibration
[ 0.000000] Detected 2259.541 MHz processor.
[ 0.016004] Calibrating delay loop (skipped), value calculated using timer frequency.. 4519.08 BogoMIPS (lpj=9038164)
[ 0.016008] pid_max: default: 32768 minimum: 301
[ 0.016038] Security Framework initialized
[ 0.016059] AppArmor: AppArmor initialized
[ 0.016061] Yama: becoming mindful.
[ 0.016112] Mount-cache hash table entries: 512
[ 0.016225] Initializing cgroup subsys cpuacct
[ 0.016231] Initializing cgroup subsys memory
[ 0.016239] Initializing cgroup subsys devices
[ 0.016241] Initializing cgroup subsys freezer
[ 0.016243] Initializing cgroup subsys blkio
[ 0.016249] Initializing cgroup subsys perf_event
[ 0.016510] mce: CPU supports 0 MCE banks
[ 0.016600] using mwait in idle threads.
[ 0.018906] SMP alternatives: switching to UP code
[ 0.323989] Freeing SMP alternatives: 24k freed
[ 0.324956] ACPI: Core revision 20110623
[ 0.326366] ACPI: setting ELCR to 0200 (from 0e20)
[ 0.326654] ftrace: allocating 26594 entries in 53 pages
[ 0.351798] weird, boot CPU (#0) not listed by the BIOS.
[ 0.351867] SMP motherboard not detected.
[ 0.351911] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.356021] SMP disabled
[ 0.356021] Performance Events: unsupported p6 CPU model 23 no PMU driver, software events only.
[ 0.356021] NMI watchdog disabled (cpu0): hardware events not enabled
[ 0.356021] Brought up 1 CPUs
[ 0.356021] Total of 1 processors activated (4519.08 BogoMIPS).
[ 0.356021] devtmpfs: initialized
[ 0.356021] EVM: security.selinux
[ 0.356021] EVM: security.SMACK64
[ 0.356021] EVM: security.capability
[ 0.356021] print_constraints: dummy:
[ 0.356021] RTC time: 15:26:46, date: 07/09/12
[ 0.356021] NET: Registered protocol family 16
[ 0.356021] EISA bus registered
[ 0.356021] ACPI: bus type pci registered
[ 0.378839] PCI : PCI BIOS aera is rw and x. Use pci=nobios if you want it NX.
[ 0.378869] PCI: PCI BIOS revision 2.10 entry at 0xfc050, last bus=0
[ 0.378872] PCI: Using configuration type 1 for base access
[ 0.379986] bio: create slab <bio-0> at 0
[ 0.380023] ACPI: Added _OSI(Module Device)
[ 0.380023] ACPI: Added _OSI(Processor Device)
[ 0.380023] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.380023] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.380129] ACPI: EC: Look up EC in DSDT
[ 0.380453] ACPI: Executed 1 blocks of module-level executable AML code
[ 0.383678] ACPI: Interpreter enabled
[ 0.383686] ACPI: (supports S0 S5)
[ 0.383697] ACPI: Using PIC for interrupt routing
[ 0.386796] ACPI: No dock devices found.
[ 0.386799] HEST: Table not found.
[ 0.386804] PCI: Ignoring host bridge windows from ACPI; if necessary, use "pci=use_crs" and report a bug
[ 0.386877] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.387022] pci_root PNP0A03:00: host bridge window [io 0x0000-0x0cf7] (ignored)
[ 0.387025] pci_root PNP0A03:00: host bridge window [io 0x0d00-0xffff] (ignored)
[ 0.387027] pci_root PNP0A03:00: host bridge window [mem 0x000a0000-0x000bffff] (ignored)
[ 0.387030] pci_root PNP0A03:00: host bridge window [mem 0xa0000000-0xffdfffff] (ignored)
[ 0.387091] pci 0000:00:00.0: [8086:1237] type 0 class 0x000600
[ 0.387600] pci 0000:00:01.0: [8086:7000] type 0 class 0x000601
[ 0.388669] pci 0000:00:01.1: [8086:7111] type 0 class 0x000101
[ 0.389259] pci 0000:00:01.1: reg 20: [io 0xd000-0xd00f]
[ 0.389682] pci 0000:00:02.0: [80ee:beef] type 0 class 0x000300
[ 0.393127] pci 0000:00:02.0: reg 10: [mem 0xe0000000-0xe0ffffff pref]
[ 0.433965] pci 0000:00:03.0: [8086:100e] type 0 class 0x000200
[ 0.438837] pci 0000:00:03.0: reg 10: [mem 0xf0000000-0xf001ffff]
[ 0.450670] pci 0000:00:03.0: reg 18: [io 0xd010-0xd017]
[ 0.475283] pci 0000:00:04.0: [80ee:cafe] type 0 class 0x000880
[ 0.481850] pci 0000:00:04.0: reg 10: [io 0xd020-0xd03f]
[ 0.486800] pci 0000:00:04.0: reg 14: [mem 0xf0400000-0xf07fffff]
[ 0.493759] pci 0000:00:04.0: reg 18: [mem 0xf0800000-0xf0803fff pref]
[ 0.517390] pci 0000:00:05.0: [8086:2415] type 0 class 0x000401
[ 0.517819] pci 0000:00:05.0: reg 10: [io 0xd100-0xd1ff]
[ 0.518119] pci 0000:00:05.0: reg 14: [io 0xd200-0xd23f]
[ 0.519135] pci 0000:00:06.0: [106b:003f] type 0 class 0x000c03
[ 0.522838] pci 0000:00:06.0: reg 10: [mem 0xf0804000-0xf0804fff]
[ 0.558466] pci 0000:00:07.0: [8086:7113] type 0 class 0x000680
[ 0.560424] pci 0000:00:08.0: [8086:100e] type 0 class 0x000200
[ 0.565509] pci 0000:00:08.0: reg 10: [mem 0xf0820000-0xf083ffff]
[ 0.575748] pci 0000:00:08.0: reg 18: [io 0xd240-0xd247]
[ 0.601712] pci 0000:00:0b.0: [8086:265c] type 0 class 0x000c03
[ 0.606636] pci 0000:00:0b.0: reg 10: [mem 0xf0840000-0xf0840fff]
[ 0.643018] pci 0000:00:0d.0: [8086:2829] type 0 class 0x000106
[ 0.647572] pci 0000:00:0d.0: reg 10: [io 0xd248-0xd24f]
[ 0.659676] pci 0000:00:0d.0: reg 18: [io 0xd258-0xd25f]
[ 0.671563] pci 0000:00:0d.0: reg 20: [io 0xd270-0xd27f]
[ 0.678345] pci 0000:00:0d.0: reg 24: [mem 0xf0842000-0xf0843fff]
[ 0.685590] pci_bus 0000:00: on NUMA node 0
[ 0.685902] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.687852] pci0000:00: Unable to request _OSC control (_OSC support mask: 0x1e)
[ 0.698865] ACPI: PCI Interrupt Link [LNKA] (IRQs *5 9 10 11)
[ 0.699168] ACPI: PCI Interrupt Link [LNKB] (IRQs 5 9 10 *11)
[ 0.699274] ACPI: PCI Interrupt Link [LNKC] (IRQs 5 9 *10 11)
[ 0.699372] ACPI: PCI Interrupt Link [LNKD] (IRQs 5 *9 10 11)
[ 0.699871] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.699876] vgaarb: loaded
[ 0.699878] vgaarb: bridge control possible 0000:00:02.0
[ 0.700043] i2c-core: driver [aat2870] using legacy suspend method
[ 0.700043] i2c-core: driver [aat2870] using legacy resume method
[ 0.700043] SCSI subsystem initialized
[ 0.700043] libata version 3.00 loaded.
[ 0.700043] usbcore: registered new interface driver usbfs
[ 0.700043] usbcore: registered new interface driver hub
[ 0.700043] usbcore: registered new device driver usb
[ 0.700043] PCI: Using ACPI for IRQ routing
[ 0.700043] PCI: pci_cache_line_size set to 64 bytes
[ 0.700202] reserve RAM buffer: 000000000009fc00 - 000000000009ffff
[ 0.700227] reserve RAM buffer: 000000009fff0000 - 000000009fffffff
[ 0.700497] NetLabel: Initializing
[ 0.700517] NetLabel: domain hash size = 128
[ 0.700533] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.700576] NetLabel: unlabeled traffic allowed by default
[ 0.709963] AppArmor: AppArmor Filesystem Enabled
[ 0.710264] pnp: PnP ACPI init
[ 0.710516] ACPI: bus type pnp registered
[ 0.710858] pnp 00:00: [bus 00-ff]
[ 0.711051] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.711218] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.711369] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.711519] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.711643] pnp 00:00: [mem 0xa0000000-0xffdfffff window]
[ 0.711792] pnp 00:00: Plug and Play ACPI device, IDs PNP0a03 (active)
[ 0.711911] pnp 00:01: [io 0x0060]
[ 0.711916] pnp 00:01: [io 0x0064]
[ 0.712298] pnp 00:01: [irq 1]
[ 0.712400] pnp 00:01: Plug and Play ACPI device, IDs PNP0303 (active)
[ 0.712471] pnp 00:02: [io 0x0000-0x000f]
[ 0.712526] pnp 00:02: [io 0x0080-0x008f]
[ 0.712577] pnp 00:02: [io 0x00c0-0x00df]
[ 0.712623] pnp 00:02: [dma 4]
[ 0.712688] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.712776] pnp 00:03: [irq 12]
[ 0.712845] pnp 00:03: Plug and Play ACPI device, IDs PNP0f03 (active)
[ 0.712891] pnp 00:04: [io 0x0378-0x037f]
[ 0.712920] pnp 00:04: [io 0x0778-0x077f]
[ 0.712946] pnp 00:04: [irq 7]
[ 0.713000] pnp 00:04: Plug and Play ACPI device, IDs PNP0400 (active)
[ 0.714505] pnp: PnP ACPI: found 5 devices
[ 0.714512] ACPI: ACPI bus type pnp unregistered
[ 0.714521] PnPBIOS: Disabled by ACPI PNP
[ 0.752387] Switching to clocksource acpi_pm
[ 0.752450] PCI: max bus depth: 0 pci_try_num: 1
[ 0.752464] pci_bus 0000:00: resource 0 [io 0x0000-0xffff]
[ 0.752466] pci_bus 0000:00: resource 1 [mem 0x00000000-0xfffffffff]
[ 0.752542] NET: Registered protocol family 2
[ 0.752646] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.753094] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.754227] TCP bind hash table entries: 65536 (order: 7, 524288 bytes)
[ 0.754385] TCP: Hash tables configured (established 131072 bind 65536)
[ 0.754392] TCP reno registered
[ 0.754395] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.754419] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.754553] NET: Registered protocol family 1
[ 0.754579] pci 0000:00:00.0: Limiting direct PCI/PCI transfers
[ 0.754622] pci 0000:00:01.0: Activating ISA DMA hang workarounds
[ 0.754666] pci 0000:00:02.0: Boot video device
[ 0.755148] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 11
[ 0.755157] PCI: setting IRQ 11 as level-triggered
[ 0.755168] pci 0000:00:06.0: PCI INT A -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 0.811275] pci 0000:00:06.0: PCI INT A disabled
[ 0.814794] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 10
[ 0.814871] PCI: setting IRQ 10 as level-triggered
[ 0.815009] pci 0000:00:0b.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 0.816376] pci 0000:00:0b.0: PCI INT A disabled
[ 0.816871] PCI: CLS 64 bytes, default 64
[ 0.817064] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.817438] audit: initializing netlink socket (disabled)
[ 0.817460] type=2000 audit(1341847606.816:1): initialized
[ 0.842637] Trying to unpack rootfs image as initramfs...
[ 0.923598] highmem bounce pool size: 64 pages
[ 0.923652] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.951484] VFS: Disk quotas dquot_6.5.2
[ 0.951707] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.954799] fuse init (API version 7.17)
[ 0.955003] msgmni has been set to 1674
[ 0.970316] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.970413] io scheduler noop registered
[ 0.970418] io scheduler deadline registered
[ 0.970429] io scheduler cfq registered (default)
[ 0.970562] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.970590] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.971363] ACPI: Deprecated procfs I/F for AC is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 0.971836] ACPI: AC Adapter [AC] (on-line)
[ 0.972673] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input0
[ 0.972683] ACPI: Power Button [PWRF]
[ 0.972773] input: Sleep Button as /devices/LNXSYSTM:00/LNXSLPBN:00/input/input1
[ 0.972776] ACPI: Sleep Button [SLPF]
[ 0.974359] ACPI: Deprecated procfs I/F for battery is loaded, please retry with CONFIG_ACPI_PROCFS_POWER cleared
[ 0.974373] ACPI: Battery Slot [BAT0] (battery present)
[ 0.974428] ERST: Table is not found!
[ 0.974435] GHES: HEST is not enabled!
[ 0.974535] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.985433] ACPI: Battery Slot [BAT0] (battery present)
[ 0.985455] isapnp: Scanning for PnP cards...
[ 0.992138] Linux agpgart interface v0.103
[ 0.993542] brd: module loaded
[ 0.994242] loop: module loaded
[ 0.994421] ahci 0000:00:0d.0: version 3.0
[ 0.995240] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 5
[ 0.995243] PCI: setting IRQ 5 as level-triggered
[ 0.995255] ahci 0000:00:0d.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 0.995437] ahci: SSS flag set, parallel bus scan disabled
[ 0.995740] ahci 0000:00:0d.0: AHCI 0001.0100 32 slots 2 ports 3 Gbps 0x3 impl SATA mode
[ 0.995744] ahci 0000:00:0d.0: flags: 64bit ncq stag only ccc
[ 1.040029] scsi0 : ahci
[ 1.045599] scsi1 : ahci
[ 1.045745] ata1: SATA max UDMA/133 abar m8192@0xf0842000 port 0xf0842100 irq 5
[ 1.045812] ata2: SATA max UDMA/133 abar m8192@0xf0842000 port 0xf0842180 irq 5
[ 1.046233] ata_piix 0000:00:01.1: version 2.13
[ 1.046829] scsi2 : ata_piix
[ 1.047175] scsi3 : ata_piix
[ 1.047223] ata3: PATA max UDMA/33 cmd 0x1f0 ctl 0x3f6 bmdma 0xd000 irq 14
[ 1.047230] ata4: PATA max UDMA/33 cmd 0x170 ctl 0x376 bmdma 0xd008 irq 15
[ 1.047616] Fixed MDIO Bus: probed
[ 1.047637] tun: Universal TUN/TAP device driver, 1.6
[ 1.047639] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 1.047694] PPP generic driver version 2.4.2
[ 1.047810] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.047846] ehci_hcd 0000:00:0b.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 1.047906] ehci_hcd 0000:00:0b.0: EHCI Host Controller
[ 1.047958] ehci_hcd 0000:00:0b.0: new USB bus registered, assigned bus number 1
[ 1.048515] ehci_hcd 0000:00:0b.0: irq 10, io mem 0xf0840000
[ 1.061737] ehci_hcd 0000:00:0b.0: USB 2.0 started, EHCI 1.00
[ 1.062221] hub 1-0:1.0: USB hub found
[ 1.062271] hub 1-0:1.0: 8 ports detected
[ 1.062434] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.062509] ohci_hcd 0000:00:06.0: PCI INT A -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 1.062598] ohci_hcd 0000:00:06.0: OHCI Host Controller
[ 1.062717] ohci_hcd 0000:00:06.0: new USB bus registered, assigned bus number 2
[ 1.062757] ohci_hcd 0000:00:06.0: irq 11, io mem 0xf0804000
[ 1.128449] hub 2-0:1.0: USB hub found
[ 1.128468] hub 2-0:1.0: 8 ports detected
[ 1.128939] uhci_hcd: USB Universal Host Controller Interface driver
[ 1.129012] usbcore: registered new interface driver libusual
[ 1.129058] i8042: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f03:PS2M] at 0x60,0x64 irq 1,12
[ 1.129609] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.129621] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 1.129758] mousedev: PS/2 mouse device common for all mice
[ 1.130249] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.130776] rtc_cmos rtc_cmos: rtc core: registered rtc_cmos as rtc0
[ 1.130821] rtc0: alarms up to one day, 114 bytes nvram
[ 1.130886] device-mapper: uevent: version 1.0.3
[ 1.130967] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 1.130998] EISA: Probing bus 0 at eisa.0
[ 1.131036] Cannot allocate resource for EISA slot 4
[ 1.131066] EISA: Detected 0 cards.
[ 1.131089] cpufreq-nforce2: No nForce2 chipset.
[ 1.131092] cpuidle: using governor ladder
[ 1.131094] cpuidle: using governor menu
[ 1.131099] EFI Variables Facility v0.08 2004-May-17
[ 1.131332] TCP cubic registered
[ 1.131455] NET: Registered protocol family 10
[ 1.132003] NET: Registered protocol family 17
[ 1.132016] Registering the dns_resolver key type
[ 1.132016] Using IPI No-Shortcut mode
[ 1.132016] PM: Hibernation image not present or could not be loaded.
[ 1.132016] registered taskstats version 1
[ 1.215056] ata4.00: ATAPI: VBOX CD-ROM, 1.0, max UDMA/133
[ 1.216406] ata4.00: configured for UDMA/33
[ 1.441232] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 1.441430] ata1.00: ATA-6: VBOX HARDDISK, 1.0, max UDMA/133
[ 1.441490] ata1.00: 16777216 sectors, multi 128: LBA48 NCQ (depth 31/32)
[ 1.441694] ata1.00: configured for UDMA/133
[ 1.654024] isapnp: No Plug & Play device found
[ 1.658555] scsi 0:0:0:0: Direct-Access ATA VBOX HARDDISK 1.0 PQ: 0 ANSI: 5
[ 1.658964] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.659586] sd 0:0:0:0: [sda] 16777216 512-byte logical blocks: (8.58 GB/8.00 GiB)
[ 1.659746] sd 0:0:0:0: [sda] Write Protect is off
[ 1.659753] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.659803] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.673223] usb 1-1: new high-speed USB device number 2 using ehci_hcd
[ 1.705393] sda: sda1 sda2 < sda5 >
[ 1.705946] sd 0:0:0:0: [sda] Attached SCSI disk
[ 1.806183] Freeing initrd memory: 13796k freed
[ 1.840829] Switching to clocksource tsc
[ 1.870900] Magic number: 4:646:436
[ 1.871038] rtc_cmos rtc_cmos: setting system clock to 2012-07-09 15:26:48 UTC (1341847608)
[ 1.871061] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 1.871066] EDD information not available.
[ 1.928763] hrtimer: interrupt took 36001599 ns
[ 2.022731] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 2.023099] ata2.00: ATA-6: VBOX HARDDISK, 1.0, max UDMA/133
[ 2.023731] ata2.00: 41943040 sectors, multi 128: LBA48 NCQ (depth 31/32)
[ 2.024196] ata2.00: configured for UDMA/133
[ 2.024767] scsi 1:0:0:0: Direct-Access ATA VBOX HARDDISK 1.0 PQ: 0 ANSI: 5
[ 2.024767] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 2.024767] scsi 3:0:0:0: CD-ROM VBOX CD-ROM 1.0 PQ: 0 ANSI: 5
[ 2.024767] sd 1:0:0:0: [sdb] 41943040 512-byte logical blocks: (21.4 GB/20.0 GiB)
[ 2.024767] sr0: scsi3-mmc drive: 32x/32x xa/form2 tray
[ 2.024767] cdrom: Uniform CD-ROM driver Revision: 3.20
[ 2.024767] sr 3:0:0:0: Attached scsi CD-ROM sr0
[ 2.024767] sr 3:0:0:0: Attached scsi generic sg2 type 5
[ 2.024767] sd 1:0:0:0: [sdb] Write Protect is off
[ 2.024767] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 2.024767] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.082842] sdb: sdb1
[ 2.086651] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 2.086651] Freeing unused kernel memory: 740k freed
[ 2.086651] Write protecting the kernel text: 5828k
[ 2.086651] Write protecting the kernel read-only data: 2376k
[ 2.086651] NX-protecting the kernel data: 4412k
[ 2.086651] udevd[88]: starting version 175
[ 2.086651] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 2.086651] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 2.086651] e1000 0000:00:03.0: PCI INT A -> Link[LNKC] -> GSI 10 (level, low) -> IRQ 10
[ 4.440750] usb 2-1: new full-speed USB device number 2 using ohci_hcd
[ 5.384842] e1000 0000:00:03.0: eth0: (PCI:33MHz:32-bit) 08:00:27:5b:c3:da
[ 5.384848] e1000 0000:00:03.0: eth0: Intel(R) PRO/1000 Network Connection
[ 5.385287] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 9
[ 5.385290] PCI: setting IRQ 9 as level-triggered
[ 5.385297] e1000 0000:00:08.0: PCI INT A -> Link[LNKD] -> GSI 9 (level, low) -> IRQ 9
[ 5.890425] e1000 0000:00:08.0: eth1: (PCI:33MHz:32-bit) 08:00:27:d2:e9:c0
[ 5.890430] e1000 0000:00:08.0: eth1: Intel(R) PRO/1000 Network Connection
[ 5.995761] input: VirtualBox USB Tablet as /devices/pci0000:00/0000:00:06.0/usb2/2-1/2-1:1.0/input/input3
[ 5.996512] generic-usb 0003:80EE:0021.0001: input,hidraw0: USB HID v1.10 Mouse [VirtualBox USB Tablet] on usb-0000:00:06.0-1/input0
[ 5.996875] usbcore: registered new interface driver usbhid
[ 5.996878] usbhid: USB HID core driver
[ 6.380178] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 11.310815] ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 11.310822] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 11.569581] udevd[468]: starting version 175
[ 11.685194] Adding 784380k swap on /dev/sda5. Priority:-1 extents:1 across:784380k
[ 12.565428] lp: driver loaded but no devices found
[ 13.022440] EXT4-fs (sda1): re-mounted. Opts: errors=remount-ro
[ 13.603520] parport_pc 00:04: reported by Plug and Play ACPI
[ 13.627738] pci 0000:00:04.0: PCI INT A -> Link[LNKD] -> GSI 9 (level, low) -> IRQ 9
[ 13.716248] piix4_smbus 0000:00:07.0: SMBus base address uninitialized - upgrade BIOS or use force_addr=0xaddr
[ 13.742995] input: Unspecified device as /devices/virtual/input/input4
[ 13.744466] vboxguest: major 0, IRQ 9, I/O port d020, MMIO at 00000000f0400000 (size 0x400000)
[ 13.744469] vboxguest: Successfully loaded version 4.1.18 (interface 0x00010004)
[ 14.134983] type=1400 audit(1341847620.759:2): apparmor="STATUS" operation="profile_load" name="/sbin/dhclient" pid=609 comm="apparmor_parser"
[ 14.135502] type=1400 audit(1341847620.759:3): apparmor="STATUS" operation="profile_load" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=609 comm="apparmor_parser"
[ 14.135745] type=1400 audit(1341847620.759:4): apparmor="STATUS" operation="profile_load" name="/usr/lib/connman/scripts/dhclient-script" pid=609 comm="apparmor_parser"
[ 14.138226] type=1400 audit(1341847620.763:5): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=611 comm="apparmor_parser"
[ 14.138796] type=1400 audit(1341847620.763:6): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=611 comm="apparmor_parser"
[ 14.139068] type=1400 audit(1341847620.763:7): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=611 comm="apparmor_parser"
[ 14.351308] input: ImExPS/2 Generic Explorer Mouse as /devices/platform/i8042/serio1/input/input5
[ 14.359560] EXT4-fs (sdb1): mounted filesystem with ordered data mode. Opts: errors=remount-ro
[ 14.778903] usbcore: registered new interface driver usbserial
[ 14.779044] USB Serial support registered for generic
[ 14.779149] usbcore: registered new interface driver usbserial_generic
[ 14.779151] usbserial: USB Serial Driver core
[ 14.854855] USB Serial support registered for FTDI USB Serial Device
[ 14.854902] ftdi_sio 1-1:1.0: FTDI USB Serial Device converter detected
[ 14.864983] usb 1-1: Detected FT2232H
[ 14.864987] usb 1-1: Number of endpoints 2
[ 14.864989] usb 1-1: Endpoint 1 MaxPacketSize 512
[ 14.864991] usb 1-1: Endpoint 2 MaxPacketSize 512
[ 14.864993] usb 1-1: Setting MaxPacketSize 512
[ 14.884729] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
[ 14.884749] ftdi_sio 1-1:1.1: FTDI USB Serial Device converter detected
[ 14.884820] usb 1-1: Detected FT2232H
[ 14.884823] usb 1-1: Number of endpoints 2
[ 14.884825] usb 1-1: Endpoint 1 MaxPacketSize 512
[ 14.884827] usb 1-1: Endpoint 2 MaxPacketSize 512
[ 14.884828] usb 1-1: Setting MaxPacketSize 512
[ 14.900741] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB1
[ 14.900813] usbcore: registered new interface driver ftdi_sio
[ 14.900815] ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
[ 16.571546] ppdev: user-space parallel port driver
[ 18.121352] snd_intel8x0 0000:00:05.0: PCI INT A -> Link[LNKA] -> GSI 5 (level, low) -> IRQ 5
[ 18.390406] init: failsafe main process (740) killed by TERM signal
[ 18.520340] intel8x0_measure_ac97_clock: measured 55481 usecs (1671 samples)
[ 18.520340] intel8x0: measured clock 30118 rejected
[ 18.880212] intel8x0: measure - unreliable DMA position..
[ 19.243175] intel8x0_measure_ac97_clock: measured 56761 usecs (3344 samples)
[ 19.243176] intel8x0: clocking to 39108
[ 20.498756] type=1400 audit(1341847627.123:8): apparmor="STATUS" operation="profile_load" name="/usr/lib/cups/backend/cups-pdf" pid=903 comm="apparmor_parser"
[ 20.511599] type=1400 audit(1341847627.135:9): apparmor="STATUS" operation="profile_load" name="/usr/sbin/cupsd" pid=903 comm="apparmor_parser"
[ 20.569816] vesafb: mode is 640x480x32, linelength=2560, pages=0
[ 20.569829] vesafb: scrolling: redraw
[ 20.569841] vesafb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[ 20.569922] mtrr: your processor doesn't support write-combining
[ 20.570104] vesafb: framebuffer at 0xe0000000, mapped to 0xf9e80000, using 1216k, total 1216k
[ 20.571553] Console: switching to colour frame buffer device 80x30
[ 20.571598] fb0: VESA VGA frame buffer device
[ 21.457619] Bluetooth: Core ver 2.16
[ 21.457669] NET: Registered protocol family 31
[ 21.457671] Bluetooth: HCI device and connection manager initialized
[ 21.457679] Bluetooth: HCI socket layer initialized
[ 21.457681] Bluetooth: L2CAP socket layer initialized
[ 21.460418] Bluetooth: SCO socket layer initialized
[ 21.610062] Bluetooth: RFCOMM TTY layer initialized
[ 21.610081] Bluetooth: RFCOMM socket layer initialized
[ 21.610095] Bluetooth: RFCOMM ver 1.11
[ 21.798307] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 21.798311] Bluetooth: BNEP filters: protocol multicast
[ 21.856736] type=1400 audit(1341847628.483:10): apparmor="STATUS" operation="profile_load" name="/usr/lib/lightdm/lightdm/lightdm-guest-session-wrapper" pid=957 comm="apparmor_parser"
[ 21.895574] type=1400 audit(1341847628.519:11): apparmor="STATUS" operation="profile_replace" name="/sbin/dhclient" pid=961 comm="apparmor_parser"
[ 21.897075] type=1400 audit(1341847628.523:12): apparmor="STATUS" operation="profile_replace" name="/usr/lib/NetworkManager/nm-dhcp-client.action" pid=961 comm="apparmor_parser"
[ 21.897383] type=1400 audit(1341847628.523:13): apparmor="STATUS" operation="profile_replace" name="/usr/lib/connman/scripts/dhclient-script" pid=961 comm="apparmor_parser"
[ 22.543309] type=1400 audit(1341847629.167:14): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince" pid=962 comm="apparmor_parser"
[ 22.558111] type=1400 audit(1341847629.183:15): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince//launchpad_integration" pid=962 comm="apparmor_parser"
[ 22.559916] type=1400 audit(1341847629.183:16): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince//sanitized_helper" pid=962 comm="apparmor_parser"
[ 22.561752] type=1400 audit(1341847629.187:17): apparmor="STATUS" operation="profile_load" name="/usr/bin/evince-previewer" pid=962 comm="apparmor_parser"
[ 24.324806] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 24.477879] e1000: eth1 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
[ 24.479749] ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 24.479897] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[ 30.221602] [drm] Initialized drm 1.1.0 20060810
[ 30.229995] pci 0000:00:02.0: PCI INT A -> Link[LNKB] -> GSI 11 (level, low) -> IRQ 11
[ 30.231592] [drm] Supports vblank timestamp caching Rev 1 (10.10.2010).
[ 30.231594] [drm] No driver support for vblank timestamp query.
[ 30.231597] [drm] Initialized vboxvideo 1.0.0 20090303 for 0000:00:02.0 on minor 0
[ 30.476364] vboxsf: Successfully loaded version 4.1.18 (interface 0x00010004)
[ 35.072241] eth0: no IPv6 routers present
[ 35.664133] eth1: no IPv6 routers present
[ 35.797253] init: plymouth-stop pre-start process (1525) terminated with status 1
JakeJake
by adafruit on Mon Jul 09, 2012 11:51 am
No, the dmesg on your -computer- not the bone
by JakeJake on Mon Jul 09, 2012 2:11 pm
That is my Ubuntu Linux machine. Take a look at line 4 of that output. The Beaglebone is running Angstrom, not Ubuntu:
JakeJake
by JakeJake on Mon Jul 09, 2012 2:28 pm
I've contacted BeagleBoard.org in TX and they said send it to them, so I have. I'll post back here with their determination when it is available.
JakeJake
by adafruit on Mon Jul 09, 2012 4:53 pm
OK ! We need to see what shows up -only- when the bone is connected/disconnected. It does appear to find the FTDI (JTAG) chipset. We suggest running dmesg right before and right after plugging in the Bone. Can you post just the -new- lines?
