Memorial day is 05/25/2015 – Orders will ship out on May 26th. There will not be any deliveries or shipping on Monday. Any order placed after 11am ET on Friday May 22nd will not start to ship out until Tuesday May 26th.
USB/serial/FTDI problem
by Bartabas on Tue Jul 24, 2012 9:57 am
I bought my bone a few days ago, I installed Ubuntu on it and it works perfectly. I installed some additional packages, python modules, as I do it on my desktop. :D
Now I encounter a problem trying to connect via the USB host to a FTDI port on a arduino card.
It works fine with my desktop, but not with the beaglebone. All look like perfect (/dev/ttyUSB0 appears, ftdi module is loaded in the kernel, dmesg seems to be happy, ...).
The ttyUSB0 are configured the same way on both desktop and bone, stty and /sys/kernel/debug/usb/devices are identicals. At bootup, the arduino card is powered up, it blinks its led the normal way. I have no error when I open ttyUSB0 through python. But the communication refuses to work, the arduino card blinks its led claiming an error each time I send data to it from the bone.
Have you an idea of what is wrong ? Do you think it could work using the clent USB port ?
Thank you in advance.
Bartabas
Re: USB/serial/FTDI problem
by adafruit_support_bill on Tue Jul 24, 2012 10:26 am
Is the bone pulling DTR low on transmit? That would reset the 'duino.
by Bartabas on Tue Jul 24, 2012 10:34 am
Hum, I don't understand your question, I'm not familiar with electronic. But I can say that the duino is not reseted, it simply blinks to signal an error.
Maybe important : I am using a 5V 1.6 Ah (not 2 Ah) power supply. The result is the same whether the duino is powered by the bone through FTDI or by an external lipo battery.
Thanks for your reply.
Bartabas
by adafruit_support_bill on Tue Jul 24, 2012 10:45 am
Here's a little background info: http://arduino.cc/playground/Hacking/FTDIAutoReset
It blinks when it resets too. How do you know there is an error?
by Bartabas on Tue Jul 24, 2012 11:27 am
Yes but in this case it blinks differently : one long blink, 2 s silence, then one medium blink and 2 short ones.
I think there is an error because normally (as it is on my desktop), the duino should answer to a question (in fact, I use the Multiwii Serial Protocol (MSP)). I wrote a python script which works correctly on my desktop. With the bone, the duino gives no answer at all, it simply blinks the way I described above.
I can be seen with simple shell commands, for example:
echo '$M>' > /dev/ttyUSB0; cat /dev/ttyUSB0
gives something on my desktop, nothing on the bone.
Some commands :
alain@omap:~$ stty -F /dev/ttyUSB0  # same on desktop
speed 115200 baud; line = 0;
eof = ^A; min = 0; time = 0;
-brkint -icrnl -imaxbel
-opost -onlcr
-isig -icanon -iexten -echo -echoe -echok -echoctl -echoke
alain@omap:~$ sudo cat /sys/kernel/debug/usb/devices # same on desktop
T:  Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#=  3 Spd=12   MxCh= 0
D:  Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs=  1
P:  Vendor=0403 ProdID=6001 Rev= 6.00
S:  Manufacturer=FTDI
S:  Product=FT232R USB UART
S:  SerialNumber=AE01A9ZG
C:* #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr= 90mA
I:* If#= 0 Alt= 0 #EPs= 2 Cls=ff(vend.) Sub=ff Prot=ff Driver=ftdi_sio
E:  Ad=81(I) Atr=02(Bulk) MxPS=  64 Ivl=0ms
E:  Ad=02(O) Atr=02(Bulk) MxPS=  64 Ivl=0ms
alain@omap:~$ lsmod
Module                  Size  Used by
nfsd                  225010  2
ftdi_sio               30552  0
usbserial              32085  1 ftdi_sio
spidev                  4708  0
snd_soc_tlv320aic3x    32602  0
alain@omap:~$ lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bartabas
by adafruit_support_bill on Tue Jul 24, 2012 11:36 am
Not being familiar with what is running on the Arduino, it is difficult to diagnose. Are you sure that the baud-rate of the Arduino sketch matches the speed you are using on the bone?
by Bartabas on Tue Jul 24, 2012 11:59 am
Yes I am sure. All works on the desktop, and the bone is configurated exactly the same way. The question, in fact, is : is it normal that the USB, on the desktop and the bone, with same drivers and configuration, have a different behaviour ?
Thanks for your patience.
Bartabas
by adafruit_support_bill on Tue Jul 24, 2012 12:17 pm
Serial port driver implementations are all over the place because the RS-232 standard is pretty vague on more than a few things. That is why I asked about the DTR. But if it is the same driver on both platforms, I would expect them to behave the same.
You might try to connect up a terminal emulator in place of the Arduino so you can see what is actually coming over the line.
by Bartabas on Wed Jul 25, 2012 4:39 am
Hum, I have to apologize: you were right, the duino is resetted. So your first proposal should be right, the bone is maybe pulling DTR low on transmit. But I have no idea how to deal with that... Could you explain what I have to do to fix this ?
Thanks you very much.
Bartabas
Re: USB/serial/FTDI problem (solved, thanks a lot)
by Bartabas on Wed Jul 25, 2012 6:08 am
SOLVED :D Thanks to your first idea, the DTR low.
Diving into the stty manual, I found the parameter to set :
stty -F  /dev/ttyUSB0 -hupcl
It disables sending a hangup signal when the last process closes the tty. Strangely, this option is not listed when querying stty. I hope this could help somebody else.
So thanks a lot, and sorry for my mistake.
Bartabas
by adafruit_support_bill on Wed Jul 25, 2012 6:25 am
Good to hear that you got it working. And thanks for the follow up! Someone may find this useful in the future. :D
