How to add new boot option on uboot?
by frodo1986 on Wed Nov 28, 2012 4:29 am
I followed this tutorial to setup wifi adapter for beaglebone (angstrom),
but when everything done, I input "reboot" and return. putty is stop and no reboot.
It's looks like this following problem.
This is a solution from this tutorial, but I do not know how to add boot option on U-Boot.
Tutorial link http://learn.adafruit.com/beaglebone/wifi
Troubleshooting
If you get an error device descriptor read/64, error -71, reboot and stop the boot process with the space bar. Then add the following boot option with the follow at the U-Boot prompt
setenv bootargs irqpoll RETURN
boot RETURN
frodo1986
Re: How to add new boot option on uboot?
by adafruit on Wed Nov 28, 2012 2:02 pm
sorry, not sure we understand, does it boot if you unplug the wifi adapter?
by frodo1986 on Fri Nov 30, 2012 5:02 am
Thank you ,adafruit.
Beaglebone still disconnect after input "reboot" command even unplug the wifi adapter.
frodo1986
by frodo1986 on Fri Nov 30, 2012 5:28 am
I use putty, when reboot beaglebone, putty said "connection abort".
And then
First, I restarted putty and log in to beagle-bone again,
edited " /var/lib/connman/settings" wifi = true,
then edited " /var/lib/connman/wifi.config" likes following,
[service_home]
Type = wifi
Name = WIFI_NAME_HERE
Security = wpa2
Passphrase = WIFI_PASS_HERE
and then "root@beaglebone:~# systemctl restart connman.service"
after more than 40 seconds, input "ifconfig wlan0", it's still a lot of 0's and no inet addr(means wifi adapter dose not connect)
Please help me.
frodo1986
by adafruit on Fri Nov 30, 2012 12:13 pm
check the name, password and password type - also get close to the router. try iwlist to list all networks available
by frodo1986 on Sat Dec 01, 2012 8:26 pm
This is my wifi.config setting
[service_home]
Type = wifi
Name = "NETGEAR03"
Security = wpa2-psk
Passphrase = "slowcheese156"
I checked them couple times, all of the information are correct, but still can not use wifi adapter
frodo1986
by frodo1986 on Sat Dec 01, 2012 8:49 pm
This is wifi adapter's information(wlan0)
It seems not support WPA2-PSK
But my router does not have WPA2 mode,
Is that meaning I need change an old router or return wifi adapter?
frodo1986
by adafruit on Tue Dec 11, 2012 10:57 pm
well, we've never had anyone with this problem. you can return the wifi module for a refund by emailing support@adafruit if you dont think it works but we suggest trying a different non-adafruit wifi module as all the ones in the shop use the same chipset - you may want to try a different one from a different store.
by frodo1986 on Sun Dec 16, 2012 6:00 am
I tried every Security type including wpa wpa2 wpa2-psk. Password and username are all correct.
"we've never had anyone with this problem"???
frodo1986
by adafruit on Mon Dec 24, 2012 1:34 pm
we can't reproduce this problem. you can return the wifi module for a refund by emailing support@adafruit if you dont think it works but we suggest trying a different non-adafruit wifi module as all the ones in the shop use the same chipset - you may want to try a different one from a different store.
