Real Time Clock for BeagleBone
by xe1xus on Mon Dec 03, 2012 12:08 pm
Dear Group,
Has anybody tried successfully to integrate a RTC module to a BeagleBone? I have a time sensitive application for BeagleBone using the supplied Angstrom distribution. I just installed and tested NTP successfully but can't sit and wait for NTP to do the necessary corrections over a long period querying online NTP servers, after a reset or power failure.
Sharing your experiences in this arena will certainly be appreciated. I don't fear the soldering iron or it's neighbours, but if the solutions come using Adafruit components, nothing will ever make me more comfortable. Thank you.
Cheers!
xe1xus
xe1xus
Re: Real Time Clock for BeagleBone
by beached on Wed Dec 05, 2012 3:04 am
What about the ntpdate command e.g. ntpdate -b ntpserver
It will set the time immediately and can generally be put into a startup script after the network is available.
beached
by xe1xus on Thu Dec 06, 2012 4:14 pm
How kind of you to reply. Thank you.
I am actually in search of integrating a hardware RTC solution into the Beaglebone. I tried your kind advise earlier with decent results. But since my application resides far out in the country with no reliable electrical mains, I thought of doing the HW RTC solution. There are times when there is electrical power available but not internet connection which at times is intermittent. This is a geophysical remote sensing scenario out of the reach of civilization :o) We get internet access from a wireless link bridging a distance of +/- 12 miles and electrical power supply is solar with DC to AC inverters. There are instruments who rely on precision time around the NTP server. We can not afford a dedicated ready made GPS, but if GPS integration with the Beaglebone is possible (again using Adafrut's components) that will be even better.
Any thoughts? In the mean time let the experimentation continue. I know something will jump out of the magicians hat.
Cheers!
xe1xus
by Shatrat on Mon Jan 21, 2013 5:08 pm
This reply may be coming too late, but I'm using the Adafruit DS1307 breakout kit with my Beaglebone and it's working quite well.
It's been a few weeks since I set it up, but I believe both Angstrom and Ubuntu recognized it and started using it without much configuration from me.
I know I did have to use 'ntpdate pool.ntp.org' and 'hwclock -w' to update the time and then write the time to the DS1307, obviously the time is not set when you first put it together.
Shatrat
by irclarke on Mon Dec 02, 2013 12:45 am
I've just setup the DS1307 on a BBB running Debian wheezy, and followed the adafruit tutorial.
Went ok apart from having to install systemctl, but all works fine.
Going to be used in a UAV logging thermal infrared imagery. Next step is GPS integration...
irclarke
