Cloud-9 IDE not working
szlztt
Post by szlztt »
I just received my BBB from you about a week ago. When I first got it setup with the proper drivers I went through the Getting started guide and got to the Cloud-9 IDE. When I try to run a sample script like the cut and past sample given in the guide it won't run by clicking in the drop down from the start button. Furthermore the sample programs that are supposed to show up in the "project files" pane are not there and there is a circle that rotates and never loads anything.
The board is working as far as I can tell because i am able to type in raw linux commands and it responds normally. Also, when i click the interactive buttons to execute code in the interactive guide it works (executes bonescript).
Please help me with the Cloud-9 IDE or please suggest another IDE window i can use to execute bonescript.
adafruit_support_mike
Re: Cloud-9 IDE not working
The version of the OS that comes from the factory can have odd quirks now and then.
Try loading the latest version of the OS into the eMMC and see if that helps.
szlztt
Post by szlztt »
Mike,
Yes that did the trick,
thanks
Return to “Beagle Bone & Adafruit Beagle Bone products”
