Adafruit_BBIO 16 bit SPI on Beaglebone
bumin
Post by bumin »
Hello everybody,
I am not sure if this is the correct place to post my problem. I am very new to the
Beaglebone and embedded systems under Linux.
I am currently trying to get a 16bit ADC running via SPI1 on my Beaglebone Black.
My OS is Debian Wheezy with the 3.8.13 kernel. So far I have disabled the HDMI
interface and got the spidev1.0 and spidev1.1 running. (Aside from my actual
problem I am not sure what the last number represents.)
I have shot wired the P9_29 and P9_30 pins to test the communication. My program is written
in Python 2.7 and I am using the Adafruit_BBIO modul to control the SPI
(https://github.com/adafruit/adafruit-be ... -io-python).
When trying to send and receive one 16-bit word with the following code:
import Adafruit_BBIO.SPI as SPI
print "Testing SPI: P9_29 and P9_30 need to be short wired"
spi = SPI.SPI()
spi.open(1,0)
spi.bpw = 16
print "Word length is : " + str(spi.bpw)
resp = spi.xfer([0x1234]) # transfer one word of two bytes length
print "Sending 0x1234 via xfer - receiving: " + str(resp)
spi.close() #close the port before exit
I only receive 8 bit, being the 8 LBS "34". The same goes for the xfer2 method.
Does somebody have any experience with this type of problem, or am I missing something obvious?
Any help would be appreciated!
Best Regards,
Bumin
adafruit_support_mike
Re: Adafruit_BBIO 16 bit SPI on Beaglebone
Try calling 'spi.set_bpw()' rather than trying to set it explicitly. That method contains some magic beyond straight value assignment.
mm_abby
Post by mm_abby »
I was able to initialize and set the bpw using Bumins method of directly setting the variable, but was not able to call it using spi.set_bpw(10).
I get the following error :
AttributeError: 'SPI' object has no attribute 'set_bpw'
please let me know if you can help.
Thank you!
Could you post the code you're using please (between CODE tags)?
mm_abby
Post by mm_abby »
It only works when I call the bpw (and all other attributes) explicitly
Below is what it looks like when i run it inside of a python shell:
>>> from Adafruit_BBIO.SPI import SPI
>>> spi = SPI(0,0)
>>> spi.set_bpw(10)
  File "<stdin>", line 1, in <module>
>>> spi.bpw=10
Thank you!
I know there have been some changes to the BBIO library, but I don't know the details. Let me check with the folks who are responsible for that code.
Return to “Beagle Bone & Adafruit Beagle Bone products”
