Ran out of PWM pins for my robot...
- js3
The 8 PWM pins on the BBB are being used for servos. I need to add control for a couple RGB leds, communicating over serial. This means I can't use neopixels or the I2c PWM BoB right? Do I need to add a micro like the Atmega 328 to get these extra PWM pins? Is there an easier way? I'm using BT, which is why I need serial communication.
- adafruit_support_mike
Re: Ran out of PWM pins for my robot...
Are you talking about a Bluetooth connection between the BBB and the LEDs?
That's the only reason you'd be handcuffed to a serial connection. If your using a Bluetooth serial connection to talk to the BBB, that only constrains that line of communication. The BBB should be able to talk to other devices using any protocol it pleases.
- js3
The serial BT connection is between an Android phone and BBB. Servos and leds work, looking to add more servos. Guess I am handcuffed to a serial connection for these motors. How would I add more?
These will drive either servos or leds: https://www.adafruit.com/product/815
These drive leds only:
https://www.adafruit.com/products/1429
https://www.adafruit.com/products/1455
- js3
These boards communicate via SPI or I2C. I need to keep it a serial communication b/c everything is controlled over bluetooth.
Add one of these between the BT and the PWM breakout(s): https://www.adafruit.com/product/1501
- js3
I'll give it a try. Are there any tutorial(s) on how to connect a second microcontroller?
If I understand your configuration properly, the BBB should be able to drive the PWM controllers directly via i2c. I don't think you need a second processor for a serial interface.The serial BT connection is between an Android phone and BBB.
If you post a diagram of the system you are trying to build, it might make things clearer.
- js3
So the robot will be controlled with an Android phone. Right now its on an Arduino Uno and I'm trying to transfer it to a BBB, but I need these extra PWM signals. 1 RGB Led and 3 servo's using PWM on the UNO. Right now the app sends a number over BT, Arduino code receives it, makes that assigned servo move. If I understand you right, the BBB(or UNO) can receive that Serial data and move those motors over the PWM driver, still keeping the wireless control?
Yes.the BBB(or UNO) can receive that Serial data and move those motors over the PWM driver, still keeping the wireless control?
- js3
Would there be any timing issues? Using a pan tilt setup, would it affect responsiveness ?
The servos themselves will be the limiting factor in responsiveness. The servo update rate is 60 Hz (16.7mS) Servo commands to the board are well under 1mS.
