ImportError: No module named Adafruit_DHT
FooLingYu2
Post by FooLingYu2 »
Hello Adafruit Community!
So I've properly attached DHT22 Humidity Sensor to my BeagleBone Black Rev C. I'm running OS BANNED on my MacBook Pro and I followed the directions provided by Adafruit on how to get my DHT22 working.
git clone https://github.com/adafruit/Adafruit_Python_DHT.git
cd Adafruit_Python_DHT
sudo apt-get upgrade
sudo apt-get install build-essential python-dev
sudo python setup.py install
cd examples
sudo ./AdafruitDHT.py 22 P8_11
  File "simpletest.py", line 23, in <module>
    import Adafruit_DHT
No problems prior to sudo ./AdafruitDHT.py 22 P8_11
Any idea why this module can't be found? I did an ls while in the Adafruit_Python_DHT directory and sure enough Adafruit_DHT was there. Any help is very much appreciated! Thank you for your time in advanced :)
tdicola
Re: ImportError: No module named Adafruit_DHT
Post by tdicola »
Can you go back to the Adafruit_Python_DHT directory root (that has the setup.py script) and run this command to force it to reinstall, and copy the output of it to paste back in the thread here:
sudo python setup.py install --force
Lets see if perhaps there's some issue with Python installing the library so it can be found by other programs.
FooLingYu2
Problem fixed! Thank you so much! You are my savior. For the past 2 weeks, I have been doing intense research trying to find out what the problem was. I can't thank you enough
root@beaglebone:~# cd Adafruit_Python_DHT
root@beaglebone:~/Adafruit_Python_DHT# sudo python setup.py install --force
Downloading https://pypi.python.org/packages/source/s/setuptools/setuptools-4.0.1.zip
Extracting in /tmp/tmpuDvt4C
Now working in /tmp/tmpuDvt4C/setuptools-4.0.1
Building a Setuptools egg in /root/Adafruit_Python_DHT
/root/Adafruit_Python_DHT/setuptools-4.0.1-py2.7.egg
running install
running bdist_egg
running egg_info
creating Adafruit_DHT.egg-info
writing Adafruit_DHT.egg-info/PKG-INFO
writing top-level names to Adafruit_DHT.egg-info/top_level.txt
writing dependency_links to Adafruit_DHT.egg-info/dependency_links.txt
writing manifest file 'Adafruit_DHT.egg-info/SOURCES.txt'
reading manifest file 'Adafruit_DHT.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-armv7l/egg
running install_lib
running build_py
creating build
creating build/lib.linux-armv7l-2.7
creating build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/__init__.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/Beaglebone_Black.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/Test.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/common.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/Raspberry_Pi.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
copying Adafruit_DHT/platform_detect.py -> build/lib.linux-armv7l-2.7/Adafruit_DHT
running build_ext
building 'Adafruit_DHT.Beaglebone_Black_Driver' extension
creating build/temp.linux-armv7l-2.7
creating build/temp.linux-armv7l-2.7/source
creating build/temp.linux-armv7l-2.7/source/Beaglebone_Black
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c source/_Beaglebone_Black_Driver.c -o build/temp.linux-armv7l-2.7/source/_Beaglebone_Black_Driver.o -std=gnu99
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c source/common_dht_read.c -o build/temp.linux-armv7l-2.7/source/common_dht_read.o -std=gnu99
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c source/Beaglebone_Black/bbb_dht_read.c -o build/temp.linux-armv7l-2.7/source/Beaglebone_Black/bbb_dht_read.o -std=gnu99
gcc -pthread -fno-strict-aliasing -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fPIC -I/usr/include/python2.7 -c source/Beaglebone_Black/bbb_mmio.c -o build/temp.linux-armv7l-2.7/source/Beaglebone_Black/bbb_mmio.o -std=gnu99
gcc -pthread -shared -Wl,-O1 -Wl,-Bsymbolic-functions -Wl,-z,relro build/temp.linux-armv7l-2.7/source/_Beaglebone_Black_Driver.o build/temp.linux-armv7l-2.7/source/common_dht_read.o build/temp.linux-armv7l-2.7/source/Beaglebone_Black/bbb_dht_read.o build/temp.linux-armv7l-2.7/source/Beaglebone_Black/bbb_mmio.o -lrt -o build/lib.linux-armv7l-2.7/Adafruit_DHT/Beaglebone_Black_Driver.so
creating build/bdist.linux-armv7l
creating build/bdist.linux-armv7l/egg
creating build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/__init__.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/Beaglebone_Black.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/Test.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/common.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/Beaglebone_Black_Driver.so -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/Raspberry_Pi.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
copying build/lib.linux-armv7l-2.7/Adafruit_DHT/platform_detect.py -> build/bdist.linux-armv7l/egg/Adafruit_DHT
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/__init__.py to __init__.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/Beaglebone_Black.py to Beaglebone_Black.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/Test.py to Test.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/common.py to common.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/Raspberry_Pi.py to Raspberry_Pi.pyc
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/platform_detect.py to platform_detect.pyc
creating stub loader for Adafruit_DHT/Beaglebone_Black_Driver.so
byte-compiling build/bdist.linux-armv7l/egg/Adafruit_DHT/Beaglebone_Black_Driver.py to Beaglebone_Black_Driver.pyc
creating build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_DHT.egg-info/PKG-INFO -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_DHT.egg-info/SOURCES.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_DHT.egg-info/dependency_links.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
copying Adafruit_DHT.egg-info/top_level.txt -> build/bdist.linux-armv7l/egg/EGG-INFO
writing build/bdist.linux-armv7l/egg/EGG-INFO/native_libs.txt
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/Adafruit_DHT-1.0.0-py2.7-linux-armv7l.egg' and adding 'build/bdist.linux-armv7l/egg' to it
removing 'build/bdist.linux-armv7l/egg' (and everything under it)
Processing setuptools-4.0.1-py2.7.egg
Copying setuptools-4.0.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Removing setuptools 3.6 from easy-install.pth file
Adding setuptools 4.0.1 to easy-install.pth file
Installing easy_install script to /usr/local/bin
Installing easy_install-2.7 script to /usr/local/bin
Installed /usr/local/lib/python2.7/dist-packages/setuptools-4.0.1-py2.7.egg
Processing dependencies for setuptools==4.0.1
Finished processing dependencies for setuptools==4.0.1
Processing Adafruit_DHT-1.0.0-py2.7-linux-armv7l.egg
Copying Adafruit_DHT-1.0.0-py2.7-linux-armv7l.egg to /usr/local/lib/python2.7/dist-packages
Adding Adafruit-DHT 1.0.0 to easy-install.pth file
Installed /usr/local/lib/python2.7/dist-packages/Adafruit_DHT-1.0.0-py2.7-linux-armv7l.egg
Processing dependencies for Adafruit-DHT==1.0.0
Finished processing dependencies for Adafruit-DHT==1.0.0
root@beaglebone:~/Adafruit_Python_DHT# cd examples/
root@beaglebone:~/Adafruit_Python_DHT/examples# sudo ./AdafruitDHT.py 22 P8_11
Temp=23.3*C  Humidity=53.7%
Temp=23.2*C  Humidity=53.7%
Temp=24.5*C  Humidity=75.3%
Temp=23.5*C  Humidity=59.3%
Temp=23.4*C  Humidity=59.1%
tdicola
Post by tdicola »
Oh no problem, glad it was a simple fix. Thanks for the followup and good luck with the project!
elementFe
Post by elementFe »
Hello there.
I'm having a similar issue, but with a different module. I am attempting to follow https://learn.adafruit.com/character-lc ... lack/usage with a beaglebone black
and receive:
root@beaglebone:~/Adafruit_Python_CharLCD/examples# python char_lcd.py
  File "char_lcd.py", line 6, in <module>
    import Adafruit_CharLCD as LCD
After attempting to --force the install as suggested in this thread, I have the same error. What comes out after the install is shown below:
root@beaglebone:~/Adafruit_Python_CharLCD# python setup.py install --force
Downloading https://pypi.python.org/packages/source/s/setuptools/setuptools-3.5.1.zip
  File "setup.py", line 2, in <module>
    use_setuptools()
  File "/root/Adafruit_Python_CharLCD/ez_setup.py", line 149, in use_setuptools
    return _do_download(version, download_base, to_dir, download_delay)
  File "/root/Adafruit_Python_CharLCD/ez_setup.py", line 107, in _do_download
  File "/root/Adafruit_Python_CharLCD/ez_setup.py", line 287, in download_setuptools
    downloader(url, saveto)
  File "/root/Adafruit_Python_CharLCD/ez_setup.py", line 194, in download_file_curl
    _clean_check(cmd, target)
  File "/root/Adafruit_Python_CharLCD/ez_setup.py", line 157, in _clean_check
    subprocess.check_call(cmd)
  File "/usr/lib/python2.7/subprocess.py", line 511, in check_call
    raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['curl', 'https://pypi.python.org/packages/source/s/setuptools/setuptools-3.5.1.zip', '--silent', '--output', '/root/Adafruit_Python_CharLCD/setuptools-3.5.1.zip']' returned non-zero exit status 60
Any suggestions? Thank you so much for your time.
tdicola
Post by tdicola »
Hrm it looks like the setup script can't install setuptools (a python package for installing python modules) because it can't download the file. The error coming from the curl utility is this one:
CURLE_SSL_CACERT (60)
Peer certificate cannot be authenticated with known CA certificates.
A few things to check:
- Make sure the board is connected to the internet.
- Make sure you don't have any proxy or other issues that might be intercepting or changing traffic from the board to the internet.
- Make sure you're running the latest Raspbian image if it's a Pi, or the latest BeagleBone Black Debian image if it's a BBB.
- If all else fails, try to manually install setuptools by running these commands:
sudo apt-get update
sudo apt-get install python-setuptools
Then try running the 'sudo python setup.py install' command again.
Return to “Beagle Bone & Adafruit Beagle Bone products”
