Unable to Connect BBB to Internet through Laptop
BuffaloFan32
Post by BuffaloFan32 »
I am trying to follow Derek Molloy's tutorial here:
http://www.youtube.com/watch?v=fzRVVtGNfj8
I was able to ping my laptop from the BBB through putty after editing my firewall settings. Now, when I try to ping 8.8.8.8 nothing happens. I believe I have followed the tutorial correctly. Here is my output:
root@beaglebone:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
^C
--- 8.8.8.8 ping statistics ---
5 packets transmitted, 0 received, 100% packet loss, time 3999ms
My limited knowledge of the BeagleBone is leading me to believe the problem is that I am trying to access the internet through gateway 192.168.7.1 instead of my wireless router. However, when I use ipconfig in Windows the to find the IP address for the wireless router and use that as the gw, I get an error from my BeagleBone saying it is unavailable
Any ideas?
adafruit_support_mike
Re: Unable to Connect BBB to Internet through Laptop
You'd need to configure your laptop to forward packets from one interface (the one that connects to you BBB) to another (the one that goes to the internet).
On Unix/Linux systems, that's done through the IP Forwarding system. On Macs, it's called 'Connection Sharing'. It's probably possible to do on Windows, but I'm afraid I don't know the internals of that OS well enough to say, "click here".
BuffaloFan32
Thanks for the reply. I think I have now tried every tutorial related sharing packets through a Windows machine and still not getting it to work. How would I know if the problem is with my computer or my wireless router?
You'd need to connect some other computer through the Ethernet port.
BuffaloFan32
I installed Wingate on my computer and now I am able to ping 8.8.8.8 from the bone through the usb port and my laptop's wireless connection. I wish I could tell you what I did in Wingate to make it work but it was little more than downloading it.
The network stack is complicated enough that it's perfectly acceptable to say, "whew, it worked!" and grab a beer (one of the lesser-known network debugging tools). ;-)
Return to “Beagle Bone & Adafruit Beagle Bone products”
