Beagle Bone & NeoPixels
- CrabbyPete
I see there is a library for Arduino for the NeoPixel will it work with a Beagle Bone Back board?
Re: Beagle Bone & NeoPixels
Nope.
Linux machines like the RasPi and BBB don't handle NeoPixels very well.
The trouble is that those kinds of machines use a 'time slicing' operating system model: each process gets a certain amount of time on the CPU (usually 10ms) then the OS suspends it, swaps in the next process, and gives that one a turn.
That's great for basic number-crunching and human-interface work (the OS can swap half a dozen processes in and out between the moment your finger hits a key and the moment the keyboard registers a keypress) but it causes problems when you want to talk to other hardware.. especially hadware whose signals are time-critical like the NeoPixel's.
The pulses in a NeoPixel signal train have to be timed to within about 10ns, and the strip sees a gap of 50 microseconds as a signal to end that set of commands and start a new one. A time-slicing OS swapping the process generating those signals out for a significant fraction of a second would have about the same effect as a pilediver on a game of Operation.
The usual solution for such jobs is to use an Arduino (or similar single-task microcontroller) as a driver for the NeoPixel strip, and let the BBB or RasPi do the heavy thinking. You can arrange a UART connection between the BBB/RasPi and the microcontroller that isn't timing critical, but feeds the microcontroller the information it needs to keep the strip going.
- pburgess
Update: have a look at Trammell Hudson's LEDscape.
https://trmm.net/LEDscape
