I'm new to the beagle bone (and linux for that matter) but think this may be a great platform for a project.
I'd like to setup a network of beagle bones (3 or more). One would act as a central controller and web server/interface and the others would monitor sensors and have outputs to assorted devices.
Are there any tutorials on how to network multiple beaglebone's together over a regular ethernet network (routers/switches). I've found many articles that show how to find the BBB mac address so I could assign static IP addresses from the routers DHCP but once that's in place... trying to figure out the coding part of how they communicate/send data to each other.
If someone could point me in the right direction it'd be much appreciated. Background: I have knowledge of C programming (took 2 classes) and have done a couple involved control projects on the arduino (couple hundred lines of code each) for different class projects but I'm not a programming or networking expert.
Send data over ethernet, 3 beaglebone's
- adafruit_support_mike
Re: Send data over ethernet, 3 beaglebone's
There are hundreds of options for passing information between computers over a TCP/IP network, but HTTP is a popular and flexible option.
You can either run a full-scale webserver on the central computer or build an application-specific server with a framework like Node.js.
Take a look at our CC3000 tutorials over in the Learning System for examples:
https://learn.adafruit.com/search?q=cc3000
You can ignore or skim the details of making the CC3000 itself work, but the parts that involve passing messages between two machines will be relevant.
