Rev C Beagle Board Black needs to be re flashed
strandbiker1
Post by strandbiker1 »
My Rev C board EMMC needs to be re flashed. It will not boot when power is applied and the EMMC flashers I have downloaded to a SD card do not work. Please provide me with a direct link to a working flash program for the Rev C board. I have been given several links to "latest images" but there are numerous ones to choose from. Is the Emmc flasher different from the Linux operating system itself. I tried to boot using this file without success. No LED's lit up (BBB-eMMC-flasher-debian-7.8-lxde-4gb-armhf-2015-01-25-4gb).
Skip
adafruit_support_rick
Re: Rev C Beagle Board Black needs to be re flashed
Post by adafruit_support_rick »
strandbiker1
adafruit_support_rick wrote:We have this tutorial available
https://learn.adafruit.com/beaglebone-b ... ng-systems
Thank you so much for the help. In reviewing your documentation, it appears to cover the 2 GB version of BBB. Is there a difference when reloaded a 4GB version of BBB?
Skip
tdicola
Post by tdicola »
I've used these images to flash my eMMC without any issues on a rev C board (4 GB eMMC): http://beagleboard.org/latest-images You want the middle ones that say eMMC flasher. If those don't work (and remember you might need to hold down the boot button as your apply power to the board so that it boots from the SD card with the flasher image), try asking in the BeagleBone Black support group for the official image and process they recommend: http://beagleboard.org/community/forums
strandbiker1
tdicola wrote:I've used these images to flash my eMMC without any issues on a rev C board (4 GB eMMC): http://beagleboard.org/latest-images You want the middle ones that say eMMC flasher. If those don't work (and remember you might need to hold down the boot button as your apply power to the board so that it boots from the SD card with the flasher image), try asking in the BeagleBone Black support group for the official image and process they recommend: http://beagleboard.org/community/forums
Yes, I saw that page before and the middle of the page that refers to the Beagle Board Black. I was confused as they only referred to the 2 GB model. I was told that I needed to get a different version EMMC flasher for the 4GB Rev C version. Has anyone been successful in updating their Rev C, 4 GB board, with these flashers? Sorry for the e mails, but I have been working on this for several days. yes I know about the boot button. I get my 5V light going on, but when I power up the board after depressing the button, I get no LED lights flashing.
Skip
strandbiker1
Okay all, thank you for the help, I was able to reload and boot the BBB Rev C finally. Only took 7 minutes to accomplish before all 4 LED's lit up.
Skip
tdicola
Post by tdicola »
Oh no problem, glad to hear it's working for you now. Thanks for the followup!
strandbiker1
What is the difference between bonescript and linux s/w packages. How can you determine what your BBB is running?
Skip
tdicola
Post by tdicola »
Sorry couldn't reply sooner but bonescript is the javascript-based programming language the BeagleBone Black ships with to support simple programming out of the box. Since it's just a Debian linux machine though you can install and use almost any programming language though like python, ruby, C++, etc. If you have more questions about bonescript you might ask folks on the BeagleBone Black forums: http://beagleboard.org/community/forums
lenmeld
Post by lenmeld »
Hi, so I flashed "BBB-eMMC-flasher-debian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img" all well and good.
However, it's asking for the password for ROOT and I've run out off guesses! Please clue me in. Thanks
tdicola
Post by tdicola »
Oh try pressing enter with no password being entered for the user root. The default debian install usually uses root with no password (they kind of hide it on this setup page). Then if you want to set a password later you can run the passwd command once logged in (it will ask for a new password to set for the current user).
lenmeld
Post by lenmeld »
tdicola wrote:Oh try pressing enter with no password being entered for the user root. The default debian install usually uses root with no password (they kind of hide it on this setup page). Then if you want to set a password later you can run the passwd command once logged in (it will ask for a new password to set for the current user).
I started with no password as that's the way the adafruit BBB was before I clobbered the eMMC and then flashed with "BBB-eMMC-flasher-debian-7.8-lxde-4gb-armhf-2015-03-01-4gb.img" to get the BBB operational again. Like I said I've tried a slew of guesses with no luck.
So, again anyone out their knows of the password for this flash version???
Stuck in limbo.....
tdicola
Post by tdicola »
Oh that's odd, try asking on the Beaglebone Black support group as the folks there make the OS images and should be able to say for sure: https://groups.google.com/forum/#!categ ... bone-black
One other thing to try is user 'debian' and password 'temppwd' (no quotes on either of them). IIRC that's the default password for some older Debian images that were floating around for the Beaglebone Black. Worth a quick shot to see if it's the same for your flashed image too.
Return to “Beagle Bone & Adafruit Beagle Bone products”
