I'm working on Beaglebone for a robotic project. Currently i'm writing a code to get moto's position using encoders.
It is working fine on slow motor speed. But the problem starts when motor speed is fast. I believe, it is due to the processing speed of Adafruit's BBIO Library and Python.
So does anyone has any idea how fast Python Adafruit_BBIO Library can go?
And any suggestion for any faster library in any other language? C++ maybe.
Python Adafruit_BBIO's maximum speed
Re: Python Adafruit_BBIO's maximum speed
Python is an interpreted language, so it has a lot more overhead than the binaries generated by a C compiler. To find the actual difference, you'd need to write programs that do the same general thing in both languages, loop them over a set of standard operations a few hundred or thousand times, and count the elapsed time for each.
- paulf8080
Just curious. Are you reading the encoder value a gpio pin at a time. If so, the encoder value can change before all pin reads are completed. Is there a way to read all the pins at once. The HW supports 32 pin groups. You may have to add an external register to capture all encoder pins at once.
