I'm using ubuntu 14.04.2 and Adafruit BBIO library.
When i execute:
UART.setup("UART4")
i detect this error
RuntimeError: Unable to export UART channel.
this is the print of: dmesg | grep tty
[ 0.000000] Kernel command line: console=ttyO0,115200n8 quiet drm.debug=7 capemgr.enable_partno=BB-UART1,BB-UART2,BB-UART4 root=UUID=854463c0-6305-4e7b-b9e7-d2edbfa8b232 ro rootfstype=ext4 rootwait fixrtc quiet
[ 0.000426] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 2.654234] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250
[ 2.671940] console [ttyS0] enabled
[ 2.673157] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 89, base_baud = 3000000) is a 8250
[ 2.674056] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 90, base_baud = 3000000) is a 8250
[ 2.674871] 481a8000.serial: ttyS4 at MMIO 0x481a8000 (irq = 61, base_baud = 3000000) is a 8250
[ 2.675645] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 62, base_baud = 3000000) is a 8250
this is the print of: ls -l /dev/tty*
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO0 -> ttyS0
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO1 -> ttyS1
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO2 -> ttyS2
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO4 -> ttyS4
crw-rw---- 1 root root 5 May 14 15:19 /dev/ttyO5 -> ttyS5
crw-rw---- 1 root tty 4, 64 May 14 15:20 /dev/ttyS0
crw-rw---- 1 root dialout 4, 65 May 14 15:19 /dev/ttyS1
crw-rw---- 1 root dialout 4, 66 May 14 15:19 /dev/ttyS2
crw-rw---- 1 root dialout 4, 67 May 14 15:19 /dev/ttyS3
crw-rw---- 1 root dialout 4, 68 May 14 15:19 /dev/ttyS4
this is the print of: uEnv.txt
#Docs: http://elinux.org/Beagleboard:U-boot_pa ... layout_2.0
uname_r=3.14.37-ti-r57
#dtb=
cmdline=quiet
#In the event of edid real failures, uncomment this next line:
#cmdline=quiet video=HDMI-A-1:1024x768@60e
##Example
#cape_disable=capemgr.disable_partno=
optargs=quiet drm.debug=7 capemgr.enable_partno=BB-UART4
##enable BBB: eMMC Flasher:
#cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh
uuid=854463c0-6305-4e7b-b9e7-d2edbfa8b232
Thank you,
Alessio
Adafruit BBIO: Unable to export UART channel
Re: Adafruit BBIO: Unable to export UART channel
Have you disabled the serial console in raspi-config?
- rivetta
I'm using a beaglebone black rev c.
Alessio
Alessio
Oh duh..
From the error messages, it looks like that UART is already being used by the serial console. Since it's already in use (by root, for a critical system function) you won't be able to do anything else with it.
I'm sure there's a way to disable the serial console, but don't know the BBB's incantation for it off the top of my head.
In practice, it would probably be easier to use one of the other existing UARTs.
- akamediasystem
Hi, I've successfully used UART4 but unfortunately I don't know for sure what's going on with your device.
You might try temporarily trying to address another UART (UART2 is an easy one, IIRC) to see if it's a pin conflict (for example, I don't recall offhand which pins HDMI uses, and I know I've run into conflicts using SPI and some of the UARTs).
I notice in your dmesg that you're trying to use three UARTs at once - it might be worth trying to address one at a time, to see if there's an overlap between any UART pin assignments.
You might also try ensuring you're running the python code as root (at times, I has weird problems with Adafruit_BBIO when not root; now I sudo -i at the start of all my BBB adventures).
Sorry I don't have a for-sure solution; hope this helps!
AKA
AKA
