Hello.
I wonder if AR1100 Touch driver supports Android Jellybean 4.2.2 on BBB or not!
Dose AR1100 support Android on BBB?
Re: Dose AR1100 support Android on BBB?
The AR1100 should register as a standard USB mouse. The calibration utility only runs under Windows, but the AR1100 itself should work with anything.
- hsson
So. after registration as standard USB mouse, should it work on BBB?adafruit_support_mike wrote:The AR1100 should register as a standard USB mouse. The calibration utility only runs under Windows, but the AR1100 itself should work with anything.
- hsson
thank you!adafruit_support_mike wrote:Yes.
LCD just was got here.
after test, i will post result
after Configuration as USB mouse, on Windows7 PC, Touch does work. but on Android, it didn't work.
Did i something wrong..?
Does the BBB work with any other kind of mouse?
