if you DID NOT program in the bootloader, you probably have the wrong fuses because the fuses ARE NOT DEFINED in the minty source code.
you MUST set the fuses as defined in the bootloader asm file, or preferrably, just program in the bootloader. you will likely regret not using the bootloader.
note that if the USB section works that doesnt mean the microcontroller is running. they are independant systems.
fuses
