This is what I've got so far: bootloader programmed in, firmware programmed in with TinyBldr, unable to talk with hyperterminal.
My minty progress
When I was at your stage I encountered 2 problems.
1. tinybld said it loaded the firmware completely, but when I checked what was on the chip using ICSP, I found that the last few lines of the HEX code were not programmed on. That happened when I was using tinybld173, tinybld18 worked fine.
2. I was not getting a good connection with the battery. However, it seems that you have soldered your leads on so that is likely not the problem. Also make sure your (-) and (+) are in the right holes (im sure they are correct, but it doesn't hurt to check).
Thanks for the tips! Without changing anything I can now get output in TeraTerm (a better hyperterminal program). I started with the board unplugged and turned off, then plugged the board in, opened teraterm at 115200, and turned the minty on.
Minty MP3! v1 3/25/2004
Resetting Card.. found CF card... Identifying CF.. set drive command id hhhhhhhh
hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
woah, weird output. looks like you're making a lot of progress tho!terpDriver wrote:Thanks for the tips! Without changing anything I can now get output in TeraTerm (a better hyperterminal program). I started with the board unplugged and turned off, then plugged the board in, opened teraterm at 115200, and turned the minty on.Code: Select all
Minty MP3! v1 3/25/2004 Resetting Card.. found CF card... Identifying CF.. set drive command id hhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhhhhhhh
Yay! I'm getting there. Now I'm trying to get MintyComm to work.
I had a classpath problem. I fixed it by adding an environment variable called CLASSPATH and defined it as "C:\Program Files\Java\jdk1.5.0_03\lib\comm.jar;."
but at least i'm getting this far:
>java MintyComm
Exception in thread "main" java.lang.NoClassDefFoundError: MintyComm
Resetting Card.. found CF card... Identifying CF.. set drive command id „Šê@ õ
101820D0504O0228HAD 2.13SanDisk SDCFB-32 ê õõxx# bytes/
sectors: 510
# sectors/cluster: 4
# reserved sectors: 0
# FATs: 2
# / entries: 510
FAT starts at sector 0x0021
/ starts at sector 0x0000009b
STA Reset
Found STA013
setting volume to -0 dB
waiting for char
0d
mp3>
So I got one minty to work. I just need to finish up by putting on a few more components for the LIon charger and the boost supply, in case i want to run off AA's. I'm still debugging minty number two, which is still dragging at the bootloader/firmware stage.
The sound I'm getting out is pretty bass heavy (not distorted though), the highs are not very present if at all, and I was wondering what values the other few minty makers out there are using for their audio output stage, and how they would describe their sound quality. I'm using:
C14, C15, C36, C40 = 33uF
R4, R5 = 10 KOhm
R6, R7 = 10 Ohm
I'm out of 33uF caps so when I get to that point with minty number two I'm going to have to order more caps for that stage anyway.
R4, R5 = 10 KOhm
R6, R7 = 10 Ohm
