So my minty works.
However, when I remove the CF card and put it into my reader it says this card is not formatted, press yes to format etc, so when I press yes the format goes to 99% and then I get an error that says unable to format. This happened with 2 of my CF cards...
CF problem
I think there are 4 resistors and 4 capacitors coming off the DAC that make up an amplification stage. Playing around with these values will probably help. What values are you using in there now?
These are mine:
C14, C15, C36, C40 = 33uF
R4, R5 = 10 KOhm
R6, R7 = 10 Ohm
My volume is loud enough for me, but it's bass heavy and missing the highs. Or for your next project you can make a CMoy headphone amplifier (with matching altoids tin).
These are mine:
R4, R5 = 10 KOhm
R6, R7 = 10 Ohm
