CF problem
Minty so good. Minty so tasty.
ryder1650
CF problem
Post by ryder1650 »
So my minty works.
However, when I remove the CF card and put it into my reader it says this card is not formatted, press yes to format etc, so when I press yes the format goes to 99% and then I get an error that says unable to format. This happened with 2 of my CF cards...
ryder1650
Post by ryder1650 »
lol, turns out a pin was bent on my card reader...is there any way to make this thing output at a higher volume?
terpDriver
Post by terpDriver »
I think there are 4 resistors and 4 capacitors coming off the DAC that make up an amplification stage. Playing around with these values will probably help. What values are you using in there now?
These are mine:
C14, C15, C36, C40 = 33uF
R4, R5 = 10 KOhm
R6, R7 = 10 Ohm
My volume is loud enough for me, but it's bass heavy and missing the highs. Or for your next project you can make a CMoy headphone amplifier (with matching altoids tin).
ryder1650
Post by ryder1650 »
I actually used 150uf for all of those caps you listed (that is what it said in eagle). It probably just made the bass even higher
Post by adafruit »
yeah. those are the output filters. the larger the serial-cap the more bass (and more volume as well)
you can move the high and low cutoffs by changing those capacitors and resistors. i tried a bunch of different values to match what i liked.
ryder1650
Post by ryder1650 »
Can you tell us what combinations would give the loudest output?
Return to “MintyMP3”
