Help with bootloader/programming, please!
by raisin on Tue Mar 07, 2006 7:50 pm
Well, so I soldered the PIC on, and connected the wires. I use the programmer from SparkFun: HERE
According to them and to here, I connected all wires correctly, but the tinybld says "COM 1 found, PIC not found". There are no solder leaks/bridges, and there is voltage at the pins of the PIC.
1) Can someone tell me what voltage at what pins should i have?
2) What else do I need to check???
3) Could the problem be with the computer/software?
Thanks for any help!!!
raisin
by raisin on Thu Mar 09, 2006 1:43 pm
Nobody? :(
Well, at least some peoples' mintys worked...
raisin
by raisin on Thu Mar 30, 2006 9:24 pm
Wow.. 162 views and no replies :(
I guess nobody else ever had that problem.
Well, I'll start over with an extra board and see if it is going to work... if not, well too bad.
raisin
by raisin on Tue May 09, 2006 1:24 pm
Okay, maybe someone at least knows this: the programming requires 5 V, and I only have 4.85. Is this sufficient or could be a problem?
raisin
no programming
by lar on Fri Dec 29, 2006 10:24 pm
did you try another pic chip?
lar
by mikeccc987 on Thu Mar 08, 2007 10:28 pm
Is your powered on, it should be? Is your PIC bad? Also i've never programmed a PIC before so don't trust me over someone else.
Mmmmm....Toasty
mikeccc987
by sliverstorm on Tue Apr 24, 2007 2:18 am
Lacking voltage could be a severe problem; one chip I just programmed earlier today gave me issues because of a six-inch ribbon cable between the (homemade) JDM programmer and the serial port. Shortened the cable and it works fine now. The issue as I understand it is the PIC doesn't enter programming mode unless a threshold voltage is reached.
Other than that, check your pins, make sure Vcc and Vss (gnd) are paired right, chip connected right, etc...
sliverstorm
cron
