PiTFT Plug'n Play image, testers needed
by notro on Fri Mar 21, 2014 8:55 am
I have made a plug'n play image for the PiTFT display. All set up and ready to go.
It has the drivers built into the kernel proper (kernel.img) which enables the display early in the boot process.
Wiki: https://github.com/notro/fbtft-spindle/wiki/FBTFT-image
Download: http://adafruit-download.s3.amazonaws.c ... -pitft.zip
Please give feedback if you try it out. Good or bad.
Update 28 Mar 2014:
The image has been updated with the following changes:
* stmpe-ts has been patched to handle lockups
* rpi_power_switch kernel module has been added
Those of you that have downloaded the previous image, can update with
sudo rpi-update
notro
Re: PiTFT Plug'n Play image, testers needed
by jay911144 on Fri Mar 21, 2014 12:38 pm
I am trying it now
jay911144
by jay911144 on Fri Mar 21, 2014 12:51 pm
It did not work for me, just blank white screen
jay911144
by pburgess on Fri Mar 21, 2014 7:25 pm
Haven't tested it extensively yet, but can report that it does boot on Model A and B Pis (both v1 and v2 of the latter).
Trying to do the image rebuild now...this is great stuff and I'd like to use it as the base image for an upcoming project!
pburgess
by turk on Sun Mar 23, 2014 6:04 am
I downloaded and installed: it seems to work.
I will test it as soon as I can deepen.
Which kernel did you use? The BETA ones?
turk
by turk on Sun Mar 23, 2014 6:17 am
I have the same problem with the backlight found with the kernel BETA:
Screenshot
Schermata 2014-03-23 alle 11.13.28.png (56.32 KiB) Viewed 904 times
turk
by turk on Sun Mar 23, 2014 6:35 am
It does not work even the Tactile switch as power button!
Why can not I edit my posts?
turk
by notro on Sun Mar 23, 2014 7:32 am
Thanks, good to know. I have never tested my kernels on model A.
It's a kernel I have built myself: https://github.com/notro/rpi-firmware/b ... /README.md
I have added a kernel module that connects GPIO252 to the Linux backlight subsystem.
See: https://github.com/notro/fbtft-spindle/ ... #backlight
You can disable this behaviour by removing gpio_backlight_device from /etc/modules
I have used a different approach not involving a kernel module.
See: https://github.com/notro/fbtft-spindle/ ... O-keyboard
notro
by turk on Sun Mar 23, 2014 9:10 am
Ok .... I read everything and understand half!
But I think you did a great job! ;)
I will do other tests and in the case I will ask advice!
turk
by notro on Sun Mar 23, 2014 8:16 pm
I have looked closer at the Adafruit power switch module. I see that it can also turn on the Pi. My solution can't do that.
I will see if I can build that module and make it available for download.
notro
by notro on Mon Mar 24, 2014 11:02 am
rpi_power_switch module can be downloaded.
I did some changes to the original driver and it's arguments:
* 'gpio_pin' must be specified, it has no default
* 'mode' default has changed from MODE_SWITCH to MODE_BUTTON
Install
$ sudo wget -P /lib/modules/$(uname -r)/extra/ tronnes.org/downloads/rpi_power_switch.ko
$ sudo depmod
Arguments
$ modinfo rpi_power_switch
parm:           gpio_pin:Switch gpio (int)
parm:           led_pin:Indicator LED gpio (default: 16, ACT) (int)
parm:           mode:Switch mode: 0-push button, 1-switch (default: push button) (int)
Use
$ sudo modprobe rpi_power_switch gpio_pin=22 mode=0
$ dmesg | tail -1
[  585.497778] Adafruit Industries' power switch driver v1.7
Make it permanent
Add to /etc/modules
notro
by metro6audio on Mon Mar 24, 2014 1:46 pm
Notro, after our previous discussions on my troubles with I2C and touch, I downloaded and installed your image. Display draws correctly, but still no touch (no I2C adapter connected or or any changes to your image, just flash, let it reboot and startx). I've ordered another PiTFT in hopes that I just crossed a line somewhere earlier in development and destroyed the touch chip. I do have access to a scope (mentioned in one of your other forum posts), but not a lot of experience using it. What should I be checking for when scoping during a touch action?
Results from a scope test will take a long time, I'm about to leave on vacation, but can do it after the first of next month. :)
metro6audio
by notro on Mon Mar 24, 2014 1:59 pm
When touch suddenly stops working, it would helpful to know for sure that the touch controller has stopped generating interrupts, to rule out the possibility that Linux stops responding to those interrupts.
GPIO24 should have LOW going pulses when touching the panel.
notro
by metro6audio on Mon Mar 24, 2014 2:10 pm
Ok, I'll look at that next week. The interrupt count in /proc does NOT increment, but like you said, could be the module or the actual hardware. I'll report back when I have some data.
metro6audio
by turk on Tue Mar 25, 2014 4:25 pm
Perfect!
I installed the module and it works perfectly.
Now I have to figure out how to configure these:
# 23 => Cursor up
# 22 => Enter
# 21 => Cursor down
Another thing, it's possible assign at a key a double feature?
Let me explain:
If I press #18 for 1 second => turn off the backlight
If I press #18 for 3 seconds => Shout down the Raspberry
Thank you very much!!
turk
