Adafruit: HDMI cable
by davidh on Fri Jul 27, 2012 8:21 pm
I was looking at the HDMI cable ID: 608 and it says its a 1.3 cable. What does this mean :?:
Cheers
David
davidh
Re: Adafruit: HDMI cable
by adafruit on Fri Jul 27, 2012 9:23 pm
davidh wrote:Hi,
Cheers
David
http://en.wikipedia.org/wiki/HDMI
Specifications
The HDMI specification defines the protocols, signals, electrical interfaces and mechanical requirements of the standard. The maximum pixel clock rate for HDMI 1.0 was 165 MHz, which was sufficient to support 1080p and WUXGA (1920×1200) at 60 Hz. HDMI 1.3 increased that to 340 MHz, which allows for higher resolution (such as WQXGA, 2560×1600) across a single digital link. An HDMI connection can either be single-link (type A/C) or dual-link (type B) and can have a video pixel rate of 25 MHz to 340 MHz (for a single-link connection) or 25 MHz to 680 MHz (for a dual-link connection). Video formats with rates below 25 MHz (e.g., 13.5 MHz for 480i/NTSC) are transmitted using a pixel-repetition scheme.
by davidh on Fri Jul 27, 2012 10:28 pm
I was reading about the HDMI cables from the link you sent. I read that HDMI 1.3 does not support 3D. Are they talking about 3D movies?
Cheers
David
davidh
by adafruit on Fri Jul 27, 2012 11:39 pm
davidh wrote:I was reading about the HDMI cables from the link you sent. I read that HDMI 1.3 does not support 3D. Are they talking about 3D movies?
Cheers
David
good overview here:
http://dvice.com/archives/2009/12/no-new-blu-ray.php
by davidh on Sat Jul 28, 2012 11:26 pm
So this cable would be fine for Raspberry Pi then?
Cheers
David
davidh
by adafruit on Sat Jul 28, 2012 11:28 pm
davidh wrote:So this cable would be fine for Raspberry Pi then?
Cheers
David
correct, it's why we stock it! :)
cheers,
adafruit support, phil
