Arduino Uno assembled in US now available in the Store @arduino & Adafruit #TeamArduinoCC
Voltage required by Pi
by davidh on Fri Aug 10, 2012 10:48 pm
I inserted the SD, plugged in the power and read TP1 and TP2 and got a reading of 4.84V. I didn't have anything else connected to it. Should it be higher than that?
Cheers
David
davidh
Re: Voltage required by Pi
by adafruit on Sat Aug 11, 2012 6:02 pm
davidh wrote:Hi,I inserted the SD, plugged in the power and read TP1 and TP2 and got a reading of 4.84V. I didn't have anything else connected to it. Should it be higher than that?
hi david,
we do not provide linux pi support, please see our previous message and check out the pi forums for questions like this! :)
thanks!
adafruit support, phil
by davidh on Sat Aug 11, 2012 6:16 pm
Will Adafruit's 5V 1A (1000mA) USB port power supply - UL Listed provide enough voltage?
Cheers
David
davidh
by adafruit on Sat Aug 11, 2012 6:18 pm
hi david!
****This adapter is great for use with an Arduino, Raspberry Pi, teensy, NETduino, etc.! Also good with our Lithium-polymer battery chargers, so you can just carry a USB cable. ***
http://www.adafruit.com/products/501
thanks,
