The new microsd adapter the cure to the blues!
by osbock on Mon Aug 20, 2012 6:56 pm
On the same day, a friend and I both accidentally put a little pressure on the sd card when unplugging something, and "Snap!" went the holder. Fortunately I have a spare, and I'm trying to fix the other one, but this low profile dohicky is a must have in my opinion.
osbock
Re: The new microsd adapter the cure to the blues!
by slurp on Tue Aug 21, 2012 4:12 pm
This does look good http://www.adafruit.com/products/966
I've not had a problem with the SD card but have an application where a smaller foot print would be helpful. How much does this card protrude from the Pi Board?
regards,
Colin
www.minisumo.org.uk
slurp
by adafruit on Tue Aug 21, 2012 9:05 pm
the SD adapter PCB sticks out about 2mm and the microsd sticks out another 2-3mm
by slurp on Mon Aug 27, 2012 2:35 pm
adafruit wrote:the SD adapter PCB sticks out about 2mm and the microsd sticks out another 2-3mm
Thanks.
Best regards,
Colin
www.minisumo.org.uk
slurp
by danips on Sun Sep 02, 2012 5:44 am
If you rotate the microSD holder 90º you will save the 2-3mm. And maybe the other 2 extra mm.
There's a cost at insert/remove ease, but I think some people may prefer that.
danips
by adafruit on Sun Sep 02, 2012 9:51 pm
we decided to go with the method we have - so that the card can be removed easily! but we'll consider the other way if enough people request it.
by westfw on Mon Sep 03, 2012 4:42 pm
There's a kickstarter project for a horizontal adapter: http://www.kickstarter.com/projects/443 ... i?ref=live
Although it looks like the poor (?) guy needs to make about 20x more boards than he originally planned on, so there may be some delay.
I think both versions have their advantages!
westfw
by osbock on Fri Oct 05, 2012 11:43 am
I personally like the Adafruit approach, as it can be used with a case. The other one would be difficult to remove without disassembling the case.
If you never need to change, it, I can see the advantages of the other approach.
BTW, I used the Adafruit adapter to fix a broken Pi. The other way wouldn't work, unless you truly never needed to change the card, since it's now glued in!
Here's the writeup:
http://baldwisdom.com/repairing-raspberry-pi-sd-holder/
osbock
by quantalume on Mon Oct 08, 2012 11:36 pm
This is a great little adapter. I don't know why they didn't use a microSD slot on the Pi to begin with, seeing how cramped for space the board is. Besides, microSD flash cards seem to be cheaper and more plentiful than their full-size brethren.
quantalume
by richms on Tue Oct 09, 2012 2:07 am
When I asked it was an issue that the micro cards are easier to go missing in a classroom environment.
richms
