WiFi not working with Raspberry Pi / Occidentalis
by PyroAVR on Sun Sep 02, 2012 7:11 pm
I have purchased two of your WiFi adapters (PID: 814, one is a Monoprice, the other is an OurLink) and I cannot get either one to work with my Raspberry Pi. I have tried with the default "Raspberrian Wheezy/sid" OS updated using the script referenced on your product page, and also with your Occidentalis version 0.2. I also tried both adapters with my Beaglebone A5, also purchased from Adafruit. I followed your tutorial on the Beaglebone pages to no avail.
I tested both adapters to make sure that they work by plugging them into an old Windows XP laptop. I was able to connect the PC to my home WiFi router with WPA2 and hidden SSID just fine! They work, just not with either of my boards.
What should I try next?
Is there any additional information that you can point me to?
If you need more info, just let me know....
Thank you in advance!
PyroAVR
Re: WiFi not working with Raspberry Pi / Occidentalis
by adafruit on Sun Sep 02, 2012 8:46 pm
how are you powering the pi?
by PyroAVR on Sun Sep 02, 2012 10:18 pm
I am powering it via a power supply I bought from Adafruit (PID:501).
The Pi is inside the Pi Box, also from Adafruit.
PyroAVR
by adafruit on Sun Sep 02, 2012 10:19 pm
PyroAVR wrote:I am powering it via a power supply I bought from Adafruit (PID:501).
that's odd, could be a bad download - we've not heard any reports of it not working - only confirmation that it works (and it's all working here on multiple pi's etc).
by PyroAVR on Sun Sep 02, 2012 10:34 pm
Alrighty, well, I could try a redownload. Out of curiosity, what driver are you using?
I noticed that the chipset on both adapters is rtl8188cus....
But the driver is rtl8192cu. Also, I've tried this on beaglebone, using rtl8192cu versus the propriatery '8192cu' driver, also without any luck. Is there any more information I can give you that would help? I can give you logs of dmesg, the output when running wpa_supplicant, and other things.
To solve the problem, I'll redownload Occidentalis tomorrow and test it out again, recording all the outputs.
Also, when running wpa_supplicant, I get this weird error:
ioctl[SIOCSIWENCODEEXT]: Operation not permitted
even when running as root....
Again, tomorrow I'll post all the logs.
PyroAVR
by PyroAVR on Mon Sep 03, 2012 2:57 pm
Okay, so upon doing more research, I have found the following:
ioctl[whatever] : someoutput
Is correlated with a driver issue. This means that for whatever reason, wpa_supplicant cannot find/utilize the drivers specified. I ran this code:
pi@raspberrypi /etc/wpa_supplicant/$ sudo wpa_supplicant -B -Dwext -iwlan0 -c wpa_supplicant.conf
and get the cryptic error messages from wpa_supplicant as I mentioned above.
Do you think it is an issue with drivers? Could they be missing?
On a side note, I did check the md5 sum of my download, it was fine.
What do you recommend?
The logs contain no information on the chip or on the wifi, oddly enough, I'll have to run through my setup process again so that I can get more info.
Thanks again.
dmesg.txt
dmesg output
(13.33 KiB) Downloaded 61 times
PyroAVR
by adafruit on Mon Sep 03, 2012 3:07 pm
huh, that's very puzzling - we're running wifi without any issues - so far no additional reports of this either, only confirmations that's all working. we'll look in to this!
by PyroAVR on Mon Sep 03, 2012 3:36 pm
Awesome! If you need anything I herby offer my services (probably not much use, but......)
I really hate to be the first one to report a problem, it's not the most positive...
But thanks for your correspondence!
Also, I have tried this on beaglebone with Angstrom 2-14-12 and 6-28-12 without any luck. I tried using connman and wpa_supplicant, and neither of those worked.
I can also supply my WiFi setup, if that would help you troubleshoot on either system.
PyroAVR
by adafruit on Wed Sep 05, 2012 10:29 am
OK - remove all other USB devices plugged in, including the keyboard and hub. connect to ethernet, then ssh into raspberrypi.local and run dmesg and send us that :)
by PyroAVR on Wed Sep 05, 2012 6:03 pm
Alrigthy! Sorry it took so long to get back to you, I've been busy.....
Anyway, here is the log file you requested, I hope this helps!
Good luck!
dmesg.txt
(120.42 KiB) Downloaded 62 times
PyroAVR
by adafruit on Thu Sep 06, 2012 5:57 pm
whats the output of ifconfig -a?
by PyroAVR on Thu Sep 06, 2012 7:35 pm
It looks something like this:
pi@raspberrypi ~ $ ifconfig -a
eth0      Link encap:Ethernet  HWaddr b8:27:eb:03:dc:ae
          inet addr:192.168.2.3  Bcast:192.168.2.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:138 errors:0 dropped:0 overruns:0 frame:0
          TX packets:98 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:18278 (17.8 KiB)  TX bytes:15978 (15.6 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:8 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:1104 (1.0 KiB)  TX bytes:1104 (1.0 KiB)
wlan0     Link encap:Ethernet  HWaddr 00:e0:4c:0d:71:76
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
PyroAVR
by adafruit on Thu Sep 06, 2012 10:20 pm
did you edit /etc/network/interfaces?
by PyroAVR on Thu Sep 06, 2012 10:31 pm
Yes, yes I did.
Now that I think about it, I had to create it.... '/etc/network' was there.... But no interfaces file....
PyroAVR
by adafruit on Thu Sep 06, 2012 10:33 pm
not sure what to say - your wifi module is working fine, but something is wrong with the way you need to connect to the network from the Pi
