7in TFT Display - "Fuzzy" video
by bprewit on Mon Sep 03, 2012 1:26 pm
Using the 7in TFT display with the raspi & the adafruit linux distro the output is too fuzzy to read .. any suggestions?
bprewit
Re: 7in TFT Display - "Fuzzy" video
by adafruit_support_bill on Tue Sep 04, 2012 5:48 am
It could be a problem in the display, the raspi output or the cable. The best way to figure out which is to start swapping components. Try a different cable if you have one. Also try a different video source with the display or a different display with the raspi.
by tetravalence on Fri Sep 07, 2012 4:20 am
Resolution might also be the problem. Try setting your resolution in config.txt to 480 x 234.
tetravalence
by adafruit on Fri Sep 07, 2012 12:17 pm
thats a good suggestions, tetra!
by tbitson on Fri Oct 05, 2012 4:13 pm
Is this the framebuffer_width and framebuffer_height values?
tbitson
by zulucat on Sat Oct 06, 2012 2:43 am
tbitson wrote:Is this the framebuffer_width and framebuffer_height values?
Wow, what a great forum! I was having the same "fuzzy" problem & setting framebuffer width & height fixed it for me. I also added the line
sdtv_aspect=3
to configuration.txt. It sets the aspect ration to 16:9.
for more info see http://elinux.org/RPi_config.txt
zulucat
by bprewit on Thu Oct 11, 2012 11:29 pm
After trying the display with a different board and cable, and using the recommended settings (sdtv_aspect=3, framebuffer_width=480, framebuffer_height=234), text on the monitor is still unreadable.
Any other suggestions?
bprewit
by adafruit_support_bill on Fri Oct 12, 2012 8:09 am
Can you post a photo of it?
by bprewit on Sun Oct 14, 2012 3:53 pm
Here's a couple .. the display actually looks better in the pictures than it does live ..
bprewit
by adafruit_support_bill on Mon Oct 15, 2012 7:53 am
Contact support@adafruit.com with a link to this thread and ask for a replacement.
by skaxxo on Sun May 05, 2013 4:07 pm
i have the same issue... any suggestions to improve this problem?
Arduino, MODs e DIY: blackstufflabs.com
skaxxo
