Using the Mini Thermal Printer
by jivings on Mon Oct 08, 2012 3:23 am
I've purchased a Mini Thermal Printer for my Raspberry Pi. The documnetation states:
This printer is ideal for interfacing with a microcontroller, you simply need a 3.3V to 5V TTL serial output from your microcontroller
Since the serial pins on the GPIO output at 3.3V I assumed that I could just connect the printer directly to the pins and it would just work without a protection circuit. Is that a naive assumption? What else do I need to do in order to use the printer?
jivings
Re: Using the Mini Thermal Printer
by adafruit on Mon Oct 08, 2012 5:03 pm
we have seen people get it working, the logic levels are fine to connect but there's a bit of code you need to interface with it and we don't have a tutorial, or recall where a tutorial could be found. you might have to google around!
