Adafruit 16ch PWM in cpp
by mikejr88 on Wed Nov 21, 2012 12:39 pm
I have been working on converting Adafruit python code to cpp. Here is my progress so far.
PCA9685.tar
(30 KiB) Downloaded 51 times
I don't know what "reset" does. I would like to stop sending a signal to the servos when my program ends. I guess I need to read the PCA9685 pdf a few more times. :-)
Hopefully this helps someone. However, I am an amateur.
Mike
mikejr88
Re: Adafruit 16ch PWM in cpp
by mikejr88 on Sat Nov 24, 2012 1:03 pm
OK. The reset function is not actually resetting the PCA9685. More like a setup function. Setting MODE1 from the default(0x11) to 0x00 starts the internal oscillator and disables ALLCALL functions of the PCA9685. Not sure I need ALLCALL functions, especially since I have a mixed I2C bus. i.e. different I2C devices.
I'm thinking function to:
reset
turn all LED's off
sleep
turn oscillator off
Mike
mikejr88
by mikejr88 on Sat Nov 24, 2012 5:32 pm
Two new PCA9685 functions
void PCA9685::reset() {
   // Turn off all LED's
   I2Cdev::writeByte(devAddr, ALLLED_ON_L, 0x00);
   I2Cdev::writeByte(devAddr, ALLLED_ON_H, 0x00);
   I2Cdev::writeByte(devAddr, ALLLED_OFF_L, 0x00);
   I2Cdev::writeByte(devAddr, ALLLED_OFF_H, 0x10);
   // oscillator off,ALLCALL off and restart PCA9685
   I2Cdev::writeByte(devAddr, PCA9685_MODE1, 0x90);
 * Stop the internal oscillator by
 * Changing bit 4 to a 1
bool PCA9685::sleepMode() {
   uint8_t oldmode;
   I2Cdev::readByte(devAddr, PCA9685_MODE1, &oldmode);
   // bitwise OR (|) if bit4 = 0 or 1 then bit4 = 1
   oldmode |= 0x10;
   return I2Cdev::writeByte(devAddr, PCA9685_MODE1, oldmode);
Mike
mikejr88
by mikejr88 on Sat Nov 24, 2012 9:28 pm
It appears you can't set the restart bit unless it is already set. Strange!
Changed my reset function.
   // oscillator off and ALLCALL off
   I2Cdev::writeByte(devAddr, PCA9685_MODE1, 0x10);
Changed setPWMFreq function
void PCA9685::setPWMFreq(float freq) {
   float prescaleval = 25000000;
   prescaleval /= 4096;
   prescaleval /= freq;
   prescaleval -= 1;
   uint8_t prescale = floor(prescaleval + 0.5);
   uint8_t oldmode;
   uint8_t newmode = (oldmode&0x7F) | 0x10; // sleep
   I2Cdev::writeByte(devAddr, PCA9685_MODE1, newmode); // go to sleep
   I2Cdev::writeByte(devAddr, PCA9685_PRESCALE, prescale); // set the prescaler
   I2Cdev::writeByte(devAddr, PCA9685_MODE1, oldmode & 0x6F); // Oscillator on
   sleep(0.005);
   //I2Cdev::writeByte(devAddr, PCA9685_MODE1, oldmode | 0x80);
Mike
P.S. Trying to give back to Adafruit. Hopefully I am helping someone.
mikejr88
