Raspberry Pi Starter Pack and USB WiFi (802.11b/g/n) Module with Antenna for Raspberry Pi
by orca on Tue Nov 27, 2012 6:55 am
I'm planning on purchasing the Raspberry Pi Starter Pack (when it comes back in stock) and the USB Wifi Module with Antenna. Do I need to get a USB Powered hub as well, or will the Pi have enough power to run with this configuration with no other USB peripherals?
orca
Re: Raspberry Pi Starter Pack and USB WiFi (802.11b/g/n) Module with Antenna for Raspberry Pi
by adafruit on Tue Nov 27, 2012 10:30 am
we've found as long as you have a GOOD power supply such as the 5.25V we stock, it can drive the wifi adapter without a hub
by Hikerd on Fri Aug 23, 2013 6:35 pm
Can this Wifi module be set to monitor mode? Thanks.
Hikerd
by adafruit_support_mike on Sat Aug 24, 2013 11:50 am
I don't think so. There's a 'Site Survey' mode which you can use with the management software, but the searching I've done in general says the Realtek drivers don't support monitor mode.
