Raspberry Pi - Adafruit PWM/Servo Driver - Error accessing 0x40
by pentac on Wed Nov 28, 2012 7:17 am
I bought the Adafruit 16-Channel 12-bit PWM/Servo Driver (from floris.cc) after reading the great tutorial:
http://learn.adafruit.com/adafruit-16-channel-servo-driver-with-raspberry-pi
from Kevin Townsend.
I assembled en connected the servo breakout to my Raspberry Pi as described.
Everything looks OK, "sudo i2cdetect -y 0" returns output as expected and described in the tutorial.
Output i2cdetect after boot Pi:
$ sudo i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: 70 -- -- -- -- -- -- --
But running the Servo_Example.py python script results in errors:
    Error accessing 0x40: Check your I2C address
Output i2cdetect after running Servo_Example.py
70: 70 71 72 -- 74 -- -- --
I double checked the board for shortages but it looks OK.
Does anyone have an idea what could be wrong?
pentac
Re: Raspberry Pi - Adafruit PWM/Servo Driver - Error accessing 0x40
by adafruit on Wed Nov 28, 2012 2:03 pm
try removing any other i2c devices, and also check your wiring that the power is good to the chip
by pentac on Wed Nov 28, 2012 5:39 pm
Thanks for the tip.
Found one bad ground connection on the bread board which caused the problem.
Now I can continue with the project. :D
pentac
